XM2 Full Auto mode at DVinfo.net
Old February 23rd, 2004, 09:00 AM   #1
XM2 Full Auto mode
Am I right in thinking that the XM2 in full auto mode will not apply the full amount of gain available (18db) but it has to be added using the rotary control?
At least, this is what happens on my particular camera.
Robin.
Old February 23rd, 2004, 02:58 PM   #2
Hmmm mine seems to turn the gain up all the time in full auto.
Catalina Productions
http://www.catalina.co.nz
Joe Lloyd is offline   Reply With Quote
Old February 23rd, 2004, 03:02 PM   #3
Robin,
The Cam will change all exposure settings automatically depending on the light situation. I have never used Full Auto for long as you never have control.
As for your statement about NOT going to 18dB gain in Full Auto I suspect the Cam just did not have to in your particular shoot. Saying that I am sure it would if the light was low enough.
I am sure one of the technical guys will comment further but do yourself a huge favour and try the manual settings ;) Good Luck
Alan McC
Alan McCormick is offline   Reply With Quote
Old February 24th, 2004, 01:37 AM   #4
Thanks guys - I should add that as a pro I always use the manual controls. It was just that I was allowing my daughter to try out the camera and it seemed to me that the gain wasn't kicking in when it should have. I then put it through tests going from normal conditions to dark areas where I wouild have expected to see all the gain being used. The only way I could do this was to press in the knurled ring and increase exposure, press the ring again and suddenly it would all happen. May be a fault, hence the query.
Robin.
Old February 24th, 2004, 02:48 AM   #5
After I replied to your earlier post I had a look at your website - :(
You put me in the dark, I guess it is/was a fault. Initially I thought you may not have understood the concept, I am wrong.
OT - I also had a look at your XM2 beachtec set-up photos and was impressed too. You have made the small XM2 look pretty cool.
Hope you suss out the problem.
Alan McC
Old February 24th, 2004, 01:45 PM   #6
Just tested mine in full auto in real low light, it did use gain but only 12db. Won't seem to go up all the way.....
Old February 24th, 2004, 04:05 PM   #7
Joe,
That's exactly it. It seems the only way to get full 18db gain is to overide auto and "dial" it on the knurled ring.
Perhaps it's inherent in the design, though why it should be so, I don't understand.;-)
Robin.
Old February 25th, 2004, 12:09 AM   #8
I had a go last night in Full Auto indoors, when I checked the exposure "sometimes" it had gone to 18dB and others only 12dB.
Did not like it anyway as it was too grainy and bright but tried it to check out the problem.
Don't know if it is built in problem???????
Alan McC
Old February 25th, 2004, 01:07 PM   #9
Maybe Canon did this on purpose because of the grainy look of 18db?
