XM2 Translucent White Balance Lens Cap? at DVinfo.net
Old February 2nd, 2004, 10:48 AM   #1
Old Boot
I remember my old Panasonic Analogue cammie had a translucent lens cap. The "clip" inside the cap acted as a "focus" point. It was very easy to focus and WB with the lens cap on. Anybody know of an equiv for the XM2? Would make life very easy indeed . . .. no searching for "white" items to WB against?
Grazie
Old February 2nd, 2004, 09:50 PM   #2
My old Panasonic MX300 had the same thing (translucent lens cap) and it worked well as I didn't need to carry a white cloth or card around. I wonder why all caps aren't like this, are they not accurate enough white balancing this way?
Andrew Hogan is offline   Reply With Quote
Old February 3rd, 2004, 01:33 AM   #3
Old Boot
Thanks Andrew. How accurate is a white cloth or card? See my point? I could always rinse, clean and dry the cap. But yes. I feel the positive options far outstretch the possible technical downsides. I used to love that little WB thing . . it just worked!
Maybe one needs to have the "light" reflected rather than seen through. I don't know . .
Grazie
Old February 3rd, 2004, 01:08 PM   #4
Retired DV Info Net Almunus
I, too, remember those old caps. I suspect that the reason they're not around any more is because they didn't work well. Remember that the basic job of white balance is to normalize white against light reflected from a subject. In that regard, the placement of a white card target can be critical in a mixed light setting (most settings). Balancing on light refracted through a transluscent white plastic lens cap would not produce reliable results.
Old February 3rd, 2004, 01:43 PM   #5
Old Boot
Yeah, Ken, my thoughts were corect on the "reflected" light front . . pity really . . .
Grazie
Old February 4th, 2004, 04:20 PM   #6
I just use the back of an index card... cheap, light, and simple. Just throw a few in your camera case or keep one in your wallet.
Evan Kubota is offline   Reply With Quote
Old February 4th, 2004, 11:55 PM   #7
Old Boot
Oh yes, the ole "White Index Card" function!! Okay . . I'll do this instead . .
Grazie
Graham Bernard is offline   Reply
