No color on Gl2 at DVinfo.net
Old January 26th, 2004, 11:10 AM   #1
No color on Gl2
I´m in PAL-land (Spain) and the analog outputs of my GL2 showed just fine on the PAL TVs, for a while. One day I lost the color on the analog outputs, and haven´t recovered it yet. Firewire is fine, and the viewfinder and LCD are also fine, but for some reason I´ve lost the color on both S-video and composite outputs. Could this be a NTSC/PAL thing catching up with me? Has this happened to anyone? Thanks!
Miquel de Pablo is offline   Reply With Quote
Old January 26th, 2004, 05:43 PM   #2
Outer Circle
So you are using the NTSC GL2 is PAL country.
Do you plug the cam straight into your multi-system TV or VCR? Could also be the TV or VCR that has a problem.
You've checked the cam to see if isn't set to B&W, I presume?
Not to me.
Old January 27th, 2004, 11:16 AM   #3
Thanks for the reply and suggestions.
Yeah - not what I intended, but I´m stuck here for a while.
I´m plugging the camera straight into a PAL TV which has no indication that it is multisystem. It´s a Sony triniton about 5 years old. The picture was (surprisingly) fine until somehow the color disappeared. I´ve tried it on another Sony TV, with the same result, so I´m thinking it´s either the cam or something with Sony TVs.
I don´t believe the cam is in B&W - the VF shows color and so does the firewire output.
