gl2 "shallow focus" at DVinfo.net
Old December 17th, 2003, 11:26 AM   #1
gl2 "shallow depth-of-field"
I was wonder how to extend the focal length without paying for it royally. I know there is a wide angle adapter, which would change the length, but, not by much.. Anyone have any ideas?
Solutions for a small planet.
Seth Richter is offline   Reply With Quote
Old December 17th, 2003, 11:41 AM   #2
Retired DV Info Net Almunus
Your question is confusing.
It's titled "shallow focus", which is a depth-of-field matter. But then you ask about changing the "focal length", which is often a matter concerning a lens' telephoto properties. Then you ask about a wide-angle adapter.
Can you clarify what you want to accomplish? Do you want to get a wider field of view or do you want to see birds' eyebrows from 1000 yards?
Old December 17th, 2003, 11:44 AM   #3
Shallow
Sorry I meant "Shallow DOF"
Old December 17th, 2003, 11:54 AM   #4
OK. Please do a Search on DOF, as this has been discussed literally hundreds of times. We have a very large body of typing on the subject. Jeff Donald has also written an extensive article here on the subject.
Bottom line: With 1/4' ccds you're very limited. Back-up, zoom-in, open your iris as wide as possible. That's the story. Has nothing to do with adapters.
Old December 17th, 2003, 12:02 PM   #5
focus
I have been trying to research it, but, after a few hours of trying to find any telephoto-type lenses that were cheep for the gl2, I decided to try and cut the middle man.
