GL2 Standby/Lock question at DVinfo.net
Old December 7th, 2003, 05:32 PM   #1
What is the advantage of using the standby/lock lever to control power to the camera v.s. the regular power swithc on the top? If I lokc my GL2 I can use the top power switch to go to playback, but not camera. What is the advantage of this?
Walter Scott is offline   Reply With Quote
Old December 7th, 2003, 06:07 PM   #2
Walter,
When you use the standby lever, all the setting changes (white balance etc) will remain. If you power off with the other switch, you loose all that.
Rob Wilson is offline   Reply With Quote
Old December 7th, 2003, 06:11 PM   #3
<<<-- Originally posted by Rob Wilson : Walter,
When you use the standby lever, all the setting changes (white balance etc) will remain. If you power off with the other switch, you loose all that. -->>>
Thanks, makes good sense!
Old December 7th, 2003, 06:16 PM   #4
humm, now that I think about this, what happens if you have the cam locked and cycyle the power switch to playback, then back to camera? does it still retain settings, or do you then lose settings?
Old December 7th, 2003, 06:19 PM   #5
Loose Em!
Old December 7th, 2003, 06:21 PM   #6
<<<-- Originally posted by Rob Wilson : Loose Em! -->>>
OK, Understood!
Old December 7th, 2003, 10:29 PM   #7
The only way to "review" you footage without loosing your settings is to use the "Rec-Search" buttons...
Jack
Jack Robertson is offline   Reply
