True 25p on XM-2 (GL2 PAL)? at DVinfo.net
Old November 14th, 2003, 06:47 AM   #1
Ok, so here's a discussion that has been going on on European boards for a while. It seems as if by switching the shutter speed on the XM-2 (the PAL version GL-2) to 1/25 while still in interlace mode will give you a true 25p image. To illustrate this I have these pictures online:
http://www.drachenauge.de/XM2-1-25.jpg
http://www.drachenauge.de/XM2-1-50.jpg
I think the difference is obvious. The problem in outdoor conditions is that you need a lot of ND filters because so much light is caught on the CCD. However, the look is great and nobody can tell me how it is technically achieved. Is this a true progressive mode?
Jan
Jan Ewert is offline   Reply With Quote
Old November 14th, 2003, 08:19 AM   #2
The 1/25 image still isn't a true progressive image but due to the slower shutter speed the blur is enough that the interlacing appears to blend almost entirely. The 1/25 image sure does look better in the still shot and you will get a nice filmic look from the video as long as there isn't any fast action in the scene.
Are those shots yours, if so I like the lighting, it's quite eyecatching.
Adrian Douglas is offline   Reply With Quote
Old November 14th, 2003, 08:29 AM   #3
Sorry to say that the pictures are not by me but by a colleague. I don't think the blurring explanation does the job - the girls on the 1/25 frame are not blurred at all and still there are no interlace artifacts on them.
Old November 14th, 2003, 09:02 AM   #4
It could be a result of the 25fps and the 1/25 shutter speed being equal. The bottom line is it is still interlaced which is evident from the lines in the 1/25 shot. If it was true progressive there wouldn't be any lines at all.
Old November 14th, 2003, 09:29 AM   #5
I heard from someone else who saw these very pictures that since the only lines that exist are red it might well be an artifact of the DV compression.
Old December 21st, 2003, 05:31 PM   #6
" so here's a discussion that has been going on on European boards for a while "
Jan, what is the link to the european board ? Thanks
Charles
'What we perceive to be may not be what we believe to be.'
Charles King is offline   Reply With Quote
Old December 21st, 2003, 07:17 PM   #7
Outer Circle
Progressive captures 1 frame at a time; frame mode captures 2 fields at almost the same time via rapid shutter and interpolation. Progressive is "cleaner."
Old December 21st, 2003, 07:57 PM   #8
Anyone know for sure, what settings on the XM2 will get the best "film look". i mean, shutter speed, exp, and so on?
Is it frame mode with 1/25 shutter? i supose it depends a lot on light and so on... anyone that has tested all modes, and played around on the xm2 a lot have a final thought on which gives the best look?
Richard James is offline   Reply With Quote
Old December 22nd, 2003, 08:37 AM   #9
<<<-- Originally posted by Charles King :
Jan, what is the link to the european board ? Thanks -->>>
The discussion I followed was in German so it probably won t be helpful to many of you but here it is:
http://216.127.95.21/47332
Old December 22nd, 2003, 08:44 AM   #10
Thanks Jan
Charles
