Where are the handle control settings? Shoulder Mount suggstion.. at DVinfo.net
Old February 8th, 2009, 11:57 AM   #1
My zoom and record controls located on the top handle do not work. I never tried them since i purhcased the camera new, but i am assuming there must be a setup somewhere in the setup menu? I cant find it in the owners manual?
Any suggestion for a shoulder mount rig to help keep the camera steady while doing footage with the GL2? Is there wven such a thing I got the idea when i saw a pic of a Panasonic Shoulder cam...
Dave
Vegas 8.0c (Build 260)-(Upgraded to Sony Vegas 10 pro)Canon GL2, Canon HV30, HF200, HF20-Sony UWP Wirelesss Mic Kit, Intel Core 2 CPU-6600@2.40GHz-3.00GB Ram
David Ruhland is offline   Reply With Quote
Old February 8th, 2009, 12:33 PM   #2
See pages 22 and 42 of the manual for details on where the controls appear on the menu systm.
Do any of the handle controls work for you?
When did you buy the camcorder?
dpalomaki@dspalomaki.com
Old February 8th, 2009, 05:11 PM   #3
Don...
Thanks... I got it... that lock under the handle was activated....
Any suggestions on a good mount suggestion to use from the shoulder?
Old February 9th, 2009, 04:42 PM   #4
Ah, as in the last sentence, on the bottom of page 35!
Sorry, but I have no specific suggestion for a shoulder mount for a GL2. Try search?
Old February 10th, 2009, 04:00 AM   #5
I use a DV MultiRigPro to mount the cam in a "shoulder-ish" position. I like it even better because from the slightly forward position I can adjust anything on the entire camera body, where as a shoulder mount means your eyes are level with teh camera and you cannot see the back (where menu & audio controls are)
Jason Robinson is offline   Reply With Quote
Old February 14th, 2009, 04:53 PM   #6
Here is one option
Shoulder Brace - Mini DV Video Camera Shoulder Brace
I've never used it though.
Don Palomaki is offline   Reply
