My stupid question
When someone records something using frame mode (in a GL-2) or progressive mode (in a VX-2000 or in some similar camcorder that would provide 24-30fps, instead of only 15), and then I capture the recording to my computer, do I need any special codec to be able to play it in my computer?
What if I want to play it in my TV? Do I need any special TV? Can I just plug the camcorder to my regular TV and using the camcorder as a player, play the shooting? Thanks. |
I'm not too sure about the VX 2000's progressive mode but with the GL2 and DVX100 the footage is converted in the camera so you can plug in to a regular TV. They both use diffeent methods but the end result is the same.
Adrian DVInfo.net Search for quick answers Where to buy? From the best in the business...DVInfo.net sponsors |
I have mixed 60i and 15p in my VX2000 and captured both in the usual settings. Both play out to TV just fine.
David Hurdon |
Capt. Quirk
Wouldn't non interlaced video cause a flicking effect on a TV?
#5 |
At 15 fps progressive there is a noticeable effect but it can be what you want for a specific look. It can also be interesting as the source for slow motion segments. I wouldn't use it for the couple's first dance but it's excellent for cards being dealt for example.
David Hurdon |
