External shotgun mic AT ATR55 at DVinfo.net
Old July 15th, 2003, 02:42 PM   #1
Hey guys,
I just purchased an Audio Technica ATR55 to help with my sound, I'm afraid it's not gonna be what I want. What mics do you all recommend. I'm on a budget fellows. Thanks,
Josh M.
Josh Martin is offline   Reply With Quote
Old July 15th, 2003, 03:09 PM   #2
Call Brian at Zot Digital, he'll help you with a mic selection. He talked me into the new NRG as opposed to the Senn or the AT. It works pretty well, though if I had the $280, I'd go get the AT 835b in a heartbeat. If I had $430, I'd upgrade to the SennM66. If I had a million, well, let's not go there.
Alex Dunn is offline   Reply With Quote
Old July 15th, 2003, 06:30 PM   #3
What kind of budget? That is , how much can you spend?
dpalomaki@dspalomaki.com
Old July 15th, 2003, 08:01 PM   #4
shotgun mic
100.00 maybe 200.00 if it was a substancial difference.
Old July 16th, 2003, 04:38 AM   #5
For low cost shotgun mics, check the Sennheisr MKE300, the Azden SGM-1X or 2X, or perhaps the recently appearing NRG Research SA-568. Keep in mind that in mics you generally get what you pay for.
Old July 16th, 2003, 08:14 AM   #6
Old Boot
I believe the MKE300 doesn't come with the XLR option. If you have the MA300 - which I do - you will be stuck with the standard plug end looking for a place to go! Senni MKE66 here, with the XLR, straight into the MA300.
Grazie
Old July 16th, 2003, 04:21 PM   #7
The low cost mics often come with a shoe mount and mini-phone plug connector so the MA300 may not be required to use them.
The ME66 is substantally above the $200 upper limit specified.
Old July 17th, 2003, 12:01 AM   #8
Old Boot
Ouch! Got it Don!
Grazie
Old July 17th, 2003, 06:09 PM   #9
Its going to be hard to find a new mike that a sound guy will like for under $200. You may be able to get the stock mike from a guy with a PDX10 or PD150 who put on an ME66 or above.
If you post on pro audio you will get some good answers.
David Ziegelheim is offline   Reply With Quote
Old July 19th, 2003, 10:56 PM   #10
If you don't need the MA-300 device can you just use XLR to mini plug??? I heard of such a device at Radio Shack I think. Beachtek makes it too right?
I was looking at the Audio-Technica AT835b mic and it only has XLR though.
http://www.veoh.com/channels/filmmaker
My clips and films.
Bob Benkosky is offline   Reply With Quote
Old July 20th, 2003, 04:14 AM   #11
There are a variety of low/medium cost made up XLR to 3.5mm Mini-jack adaptors available in the UK. Canford Audio (www.canford.co.uk) have range of high quality adaptors - type XFB is OK. Depending on mic output and cam input impedances you may need one which incorporates a matching transformer. All the Sennheiser mics are 5/600 0hm impedance which is OK for the GL2.
Provided the lead is short, there is no need to go to the expense of a balanced-unbalanced transformer. You need an XLR-3F and a 3.5mm stereo mini-jack and a length of double screen audio cable. Wire:
XLR pin 1 to mini-jack sleeve
XLR pin 2 to mini-jack tip and ring
XLR pin 3 to mini-jack sleeve (or to XLR pin 1)
I use a 20cm lead to connect my ME67 to my XM1. I find that a right angle XLR connector is more convenient than a straight one - the mic is too long already!
Alan Craven is offline   Reply With Quote
Old July 20th, 2003, 04:26 AM   #12
Old Boot
Alan, how does one locate the "direction" or identify the Pins 1 thru 3? Is that looking at the pins head on? In a clockwise or counter-clockwise rotation? I'm sure there must is an XLR convention I could look up. Are the pins numbered internally, within the plug housing?
Is it like this - looking onto a male XLR head on at the pins?
_________ 1
_____ 3 _______ 2
Grazie
Old July 20th, 2003, 08:00 AM   #13
I find it easier to describe the female of the species. This is a view looking at the outside end of the female socket. The order is 1,3,2 round the arc, with a locating rib next to pin 2.
O represents the hole for the pin.
...............3
...............O
........1.............2
........O............O
...........Flat here.....Rib Key here
..........Lock catch
.............here
Sorry, this is not very clear. I have had to use the dots to position the representations of the pins. Spaces don't seem to show up when I post.
Every XLR I have seen has its pins labelled, usually both internally and externally. I usually buy Neutrik brand
Old July 20th, 2003, 02:34 PM   #14
Old Boot
Alan - well clear - thank you! G
Old July 22nd, 2003, 12:50 AM   #15
Which mic is better.
The Audio-Technica AT835b or Canon's Zoom mic, or that NRG mic??? How can u tell how far it will pick up sound from anyhow?
It's obviously not as good as that ME66 but better than the MKE300???
I might buy that Audio Technica soon so let me know.
My clips and films.
