Image Download problems... - Page 2 at DVinfo.net
Old July 17th, 2003, 09:05 AM   #16
Chris-
I checked it out, yes, but I got screwed up somehow, like not knowing which driver to put it in...
Joshua Badour is offline   Reply With Quote
Old July 17th, 2003, 09:18 AM   #17
You'll have to download the driver from canondv.com or you can use the one on the Canon CD which was shipped with your XM2/GL2.
It is important that you specify the location and not let windows search for the driver if it fails.
Chris Fangio is offline   Reply With Quote
Old July 17th, 2003, 09:28 AM   #18
Another idea:
Open the Canon CD -> Storage Driver -> (select your Win version) -> look for the *.inf - file -> right click -> install
This should also work.
Old July 17th, 2003, 06:16 PM   #19
When you say "open the canon Cd" do you mean start the CD program?
Old July 17th, 2003, 06:17 PM   #20
Also, when I open the CD program, all it will let me do is install the solution...
EDIT: Sorry, I didn't see the edit button...
Old July 17th, 2003, 11:21 PM   #21
Josh,
no, if your Canon CD starts automatically, just close the installation window. Right click on your cd-rom drive and choose "browse" or "explorer" (don't choose "autoplay").
Chris
Old July 31st, 2003, 08:12 AM   #22
Sorry it took so long to reply...
I went into the WIN2000 file under the storage driver, and it came up with was a notepad that said CANONDV_2K.
I doubt this is the right file...
EDIT: I tried what you said, nonetheless, and the file did nothing when I hit the install button...
