2 Channel Audio
I have a shotgun mic and wirelss mic, taken into my beachtech which is then routed into my camera. From my camera controls it appears it is being recorded on two tracks (this is also what I hear in my headphones). Left and Right. When I play it back on the t.v it gets mixed.
If I pull the DV tape onto my computer, will it have two seperate tracks of audio? Do I need to do anything special to make this happen? Thanks, Chris |
#2 | ||
Old Boot
What do you mean "mixed"? Are you saying that the channels are now swapped over? Left becomes Right? Or are you saying that the audio is having a mix applied to it? If you have channel "swap" then first off check your cabling and confirm you aren't somehow swapping the channels AT the TV. How are you connecting the camera to the TV? - Question to others here: Does the XM2 have the ability to swap channels from the user menu? Quote:
What do you mean "special"? What are you considering here? What I do is plop my dv tape into a DV deck. Capture in Vegas and I have the 2 channels - L and R - laid out correctly. Now if I have swapped the channels somewhere along the line, then Vegas just allows me to "swap" 'em back. But, having given this some further thought, is it at all possible that wherever you had your Tx mic was it near or influenced BY the alignment of the shotgun. Meaning, was there very little "separation" between the 2 mics? I've had the effect of having the sound from the mouth of a Tx-ed mic person was ALSO being captured by the shotgun. In this scenario I can get some separation issues. But this isn't swapping. I'm just raising this as a possible "other" unfortunate result. Regards, Grazie Last edited by Graham Bernard; September 1st, 2007 at 12:50 AM. Reason: additional information |
Old Boot
double post - apologies - G
A digital capture will provide the two channels of audio as separate channels. How they are recorded to your computer will depend on the capability and setting of your capture software, and it can range from being audio embedded with video in a single file to two separate .WAV files (one for each channel).
dpalomaki@dspalomaki.com |
#5 |
Fred Retread
Make sure that the Beachtek's mono/stereo switch is set to "stereo," or else the signals will be mixed going into the cam, and you'll get two identical channels. Apparently yours was set correctly, but make sure it's a deliberate check you make.
"Nothing in the world can take the place of persistence..." - Calvin Coolidge "My brain is wired to want to know how other things are wired." - Me |
#6 |
Does the TV really have stereo speakers? Or does it have two speakers that each play the same mono channel? I think it depends on the TV.
