GL2 Multiple Mic Mounting at DVinfo.net
Old August 28th, 2007, 12:06 PM   #1
I bought a rode shotgun mic and a wireless senheisser mic that fits on my camera. Both the shotgun mic and the wireless receiver are made to screw into the Advanced Accessory Shoe of my gl2.
How do you guys mount both of these to your camera at the same time?
Chris
Chris Holste is offline   Reply With Quote
Old August 28th, 2007, 12:51 PM   #2
With this or this. Search on B&H for other shoe mounts.
Edward Carlson is offline   Reply With Quote
Old August 28th, 2007, 03:46 PM   #3
Old Boot
I got this:
http://www.bhphotovideo.com/c/produc...ini_Mount.html
. .stuck into this:
http://www.bhphotovideo.com/c/produc...ock_Mount.html
. . which I had my local garage weld make a Whitworth stud to a LARGE washer and cut into a "square" to slide into this:
http://www.rycote.com/products/accessories/hotshoe/
However, had I seen or known of this:
http://www.rycote.com/products/softie/mount/multimount/
. . it would just have been THAT multimount with the slide! And the garage wouldn't have been called to Arms!
Yah gotta larf! Aint yah?!
Grazie
Old August 29th, 2007, 06:36 AM   #4
Check the Sima Video Bracket SVB-1
http://www.audio-discounters.com/svb-1.html
And available from many other fine stores.
dpalomaki@dspalomaki.com
Old August 29th, 2007, 12:27 PM   #5
I use a mount like this http://droptodesign.com/test/camera_setup/
I for the life of me can't remember the manufacture, it works well, although I need to get a wing nut for the main bolt,it keeps losening.
Old August 29th, 2007, 12:45 PM   #6
Originally Posted by Steven Davis View Post
Thats was actually the one I was looking for on B&H. It looks like your best bet.
Old August 31st, 2007, 07:36 AM   #7
I found the link for the thing I use. http://www.bhphotovideo.com/c/produc...and_Sound.html The mount, or screw in the middle, is unscrewable, so you can move the mount 90 degress, to mount it sideways.
Old October 24th, 2007, 05:53 PM   #8
Steven - what mic is that on your GL2?
I like the setup, and thank you for posting pics, it really helps a newbie like me to actually see the setup.
Bill Spearman is offline   Reply With Quote
Old October 24th, 2007, 07:33 PM   #9
I run a couple of these
http://www.bhphotovideo.com/c/produc...icrophone.html
They're good mics, just long as crap though.
I will say the shock mount you see there is not the best. The blasted thing keeps coming loose and I will either have to add a lock washer or something or just get a different mount.
Old October 24th, 2007, 07:44 PM   #10
Those really are long mics! Thanks for the insight. I am just now starting to put together my own setup, and it reallly helps to learn from those more experienced. Thank you. By the way, I visited your site, and was VERY impressed. What a great way to introduce people to your service and the quality differentiation.
