Copy DV to DV at DVinfo.net
Old July 31st, 2007, 12:43 PM   #1
Copy DV to DV
Hi All:
Anyone tell me the easiest way to copy from another DV camcorder to my Cannon GL2? I need DV footage from a tape so it's essentially DV tape to DV tape copying. Thanks in advance
Tim Agnew is offline   Reply With Quote
Old July 31st, 2007, 05:01 PM   #2
You should be able to connect the two cameras with a 4-pin to 4-pin firewire cable. Put both cameras in VCR mode and play the tape on one camera while recording on the other.
