Generic ACK-E6 power supply? at DVinfo.net
Canon EOS Full Frame for HD
Old March 22nd, 2013, 12:30 PM   #1
Hi,
I was checking out the ACK-E6 power supply that allows you to work the MarkII (and others) hooked up to the power outlet and Iīve found A LOT of generic versions for around us$15 (the original one costs us$120!). Does anyone have any experience with these generic power supplies? I know that us$15 itīs extremely cheap, but lets face it that for what it does the original Canon ACK-E6 is more expensive than it should be. Is anyone working with these on a daily basis? I donīt want to burn a us$1.5k camera.
www.rafael-lopes.com
Rafael Lopes is offline   Reply With Quote
Old April 28th, 2013, 12:13 AM   #2
Re: Generic ACK-E6 power supply?
i would like to know if a $15 power supply will work fine for a few hours of use
what will you think to get just the cable?
http://www.bhphotovideo.com/c/product/590425-REG/Canon_3352B001_DR_E6_DC_Coupler.html
and get a 10000 mAh portable power supply
Amazon.com: AnkerŪ Astro3 10000mAh External Backup Battery Pack Multi-voltage Power Bank Charger for Tablets, Netbook, Digital Cameras, DV Recorders, PS Vita, Nexus 7 Nexus 10, NDS, NDSL, GoPro; iPhone 5 (Lightning Cable not Provided), iPad, iPod; HT
Thomas Wong is offline   Reply With Quote
Old May 3rd, 2013, 02:35 AM   #3
I have three of these from Hong Kong. One works fine, one of the others stopped working altogether and the third worked when I cut two adjoining plugs off and attached the wires directly.
So you pays your money and you takes your chance…
I also have one of the Canon ones. Always worked never a problem.
Avey
theactionhouse.com
Wayne Avanson is offline   Reply
