#46 | |
Re: Camcorder equal to the 5D quality?
Thanks |
#47 | |
You might want to invest in the Metabones adapter then. It will give you an additional F stop and more without loss in quality at all ... Head over to the EA50 subforum if you want more information. |
#48 | |
#49 |
I think Maurice meant to say 720p (instead of 24p). Forgive me if I'm wrong Maurice. I think the C100 records 60fps progressive at 1280x720 but not at 1920x1080, which is inexcusable for a $7,000 camera.
Canon XF300/305 camcorder does 60p at 1920x1080 http://www.usa.canon.com/cusa/profes...01e02480041726 Last edited by Alex DeJesus; March 8th, 2013 at 11:01 AM. Reason: add'tl info |
#50 | |
#51 |
You are absolutely right. My apologies. For some reason, I thought the 50 onboard Mps 4:2:2 was synonymous with 50/60p at 1080.
#52 | |
You are correct. |
#53 | |
1. Learn to focus manually. Get used to it. Way better results. You can drop down the aperture to get a larger focus area. None of that footage shown couldn't have been manually focused. 2. Add a monitor. SmallHD. Anything that's good res. Well help you focus. 3. Take material that needs professional audio with your already existing XF100 (or was it XH A1?). Intercut with 5d. 4. Get a cheap mic on to the 5d (rode videomic/stereomic pro where you can adjust the signal) and learn to use the audio levels on the 5d. This way you can use those mitt sounds and training sounds. Then you would only need the XF100 for interviews. None the suggestions now given would help you. Would still have bad lowlight with the EX1/XF300. VG20 would be worse than the 5dmarkIII, same with the VG900. Worse. C100 would be good but at six grand... Just learn to use the equipment you already have. Get some cool lenses. Shoot. Everything else depends on where that material is going. |
#54 | |
#55 |
Second vote for a used FS100. Half the price of the C100, and can do 60p and live autofocus. (If none of these three matter, then C100. But either is better than the VG900.)
#56 |
Danny, I think the XL-H1 is a wonderful camcorder with huge added benefits of being able to use different lenses... but in many ways it will not match your 5D, and is also difficult to buy new due to it being discontinued.
It would be so nice to have a 5D body that has fast AF in video mode (without needing to use ultra-slow focus via AF-ON button), but I guess we are all stuck with MF in video mode. Manual focus is not a problem for me in most situations, but for some run-n-gun filming I'd like to have the option of quick AF. Have you thought about looking at the latest Panasonic GH3? This does offer AF during video (with MF options as well) and fits a wide selection of high quality lenses from Panasonic offering AF and IS in video mode (plus all the 4/3 Olympus lenses). Your Canon L lenses (with a cheap adapter) can even be used on the GH3 too, although AF is lost. |
