5d3 - Adobe Premiere Pro - Do you use sharpen or the unsharp mask? at DVinfo.net
Canon EOS Full Frame for HD
Old February 23rd, 2013, 04:16 AM   #1
I use the standard profile with sharpness in camera all the way to the far left, and I'm trying to decide whether or not to sharpen with the "Sharpen" tool or use the unsharp mask.
In the past I've used the unsharp mask around 130 with a 1.1 radius; for fun tonight I used the sharpen tool with a "30" setting and found the results more pleasing.
Am I nuts?
Shawn Clary is offline   Reply With Quote
Old February 25th, 2013, 08:37 AM   #2
Re: 5d3 - Adobe Premiere Pro - Do you use sharpen or the unsharp mask?
Generally I use the Sharpen effect with a value of 80. Ideally you would do each clip separately but finding the maximum before artefacts appear & backing off a bit but that is very time-consuming so I tend to use a value that is good for most situations.
Old February 25th, 2013, 10:15 AM   #3
Depends really... if it's a nice medium or CU shot of people, I usually don't apply any sharpening. But for shots when I do need a little sharpening, I use "Sharpen" at around 30.
John Carroll is offline   Reply With Quote
Old February 26th, 2013, 06:52 AM   #4
tagging for later
Jerry Porter is offline   Reply With Quote
Old February 28th, 2013, 09:25 AM   #5
Sharpen at somewhere between 25 and 40 for most stuff. Just takes the edge of the softness.
On certain shots any sharpening looks nasty, but that's a good rule of thumb for me.
Tom Dowler is offline   Reply With Quote
Old February 28th, 2013, 09:41 AM   #6
Nigel, was that a mistype? i've never gone anywhere near 80. on the 5d2 i would do 20-35, and now on the c100, no more than 10.
C100 - GH4 - NYC Shooter
www.DarrenLevine.com
Old February 28th, 2013, 10:08 AM   #7
No it was not a mistype. I was referring to the 5D3 which is an entirely different beast to the 5D2. I rarely sharpen 5D2 video at all & then no more than 20-30. When I had my C300 I would not add any sharpening to that at all. Just as you can crank up the ISO on the 5D3 without any noise appearing you can crank up the sharpening to what seem like crazy levels without destroying the image in fact on the contrary it improves the image.
Old April 4th, 2013, 08:39 PM   #8
Any other filters you recommend for enhancing video? "Cheating" a good lens...?
Urban Skargren is offline   Reply With Quote
Old April 5th, 2013, 07:51 AM   #9
Urban,
In my opinion, nothing beats quality glass. The sharpening is just to counter the processing the camera does internally which of course degrades the image. But if you don't have good glass to begin with, you'll be a little bit behind the 8-ball trying to fix that in post. But if you don't have good glass, just turn your weakness into a strength and build a "look" around it... just don't go over-board.
Old April 5th, 2013, 11:31 AM   #10
So true, John. I totally agree. Still, if anybody recommends some good filters/effects I'm all ears. Especially sharpening and de-grain.
