MK III terrible artifacts in video at DVinfo.net
Canon EOS Full Frame for HD
Old February 18th, 2013, 12:53 AM   #1
I've been using a MK II for the better part of 3 years. I just picked up a MKIII. Most of my shooting only requires short clips. Friday I had a shoot that required longer record times. Every clip that I recorded over 5 minutes and 40 seconds has artifacts like the attached image. The sound is still there. Treasured is able to restore it. However, I'd like to isolate the problem and figure out a way around it.
As a test I put a different CF card in the MKIII. The same result happened. At 5:41 and on, the rest of the video was all artifacts. I also put the original card that I noticed the problem on in my MKII and recorded a long clip. There was no artifacts.
Any ideas?
Thanks in advance.
Best,
John
John Carrithers is offline   Reply With Quote
Old February 18th, 2013, 06:50 AM   #2
Re: MK III terrible artifacts in video
I'd be thinking of returning it. None of our mk3 bodies do this.
Qualified UAV Pilot with CAA PFAW
Aerial Photo / Aerial Video | Corporate Video Production
Dave Partington is offline   Reply With Quote
Old February 19th, 2013, 06:57 AM   #3
Not that it is card specific but please give a little more detail. CF or SD? What brand? etc. thanks
Last edited by Steve Frank; February 19th, 2013 at 07:01 AM. Reason: poorly worded 1st draft
Steve Frank is offline   Reply With Quote
Old February 22nd, 2013, 06:42 AM   #4
Never seen that.
Andrew Alden Miller is offline   Reply With Quote
Old February 23rd, 2013, 04:43 PM   #5
I haven't seen anything like this on my camera. Has you camera been dropped. Is it overheating?
Maurice Covington is offline   Reply With Quote
Old February 25th, 2013, 12:38 AM   #6
Nope Nothing like that here. Defective camera would be my guess.
Al Bergstein is offline   Reply With Quote
Old February 25th, 2013, 07:17 PM   #7
No problem with mine. Sounds like a defect to me.
Scott Stacy is offline   Reply With Quote
Old February 25th, 2013, 10:58 PM   #8
Do you see the same thing in the LCD while recording? I guess your camera needs to be returned.
Wild Tiger Productions
http://www.indiawilds.com/about.htm
Sabyasachi Patra is offline   Reply With Quote
Old February 26th, 2013, 03:43 PM   #9
John, does the camera have the original firmware? Just thinking that a bad installation of something like Magic Lantern might be driving this.
Do you see the problem when playing back the clips in camera, or only on the computer monitor. If the latter, then maybe a graphics card driver issue, but I wouldn't have thought that would only show on clips of a certain size or greater.
Have you tried different resolutions and frame rates? If I had to guess, I'd say corrupted files. You say you have tried different cards. What were those cards, and were they formatted in the camera or on the computer. Sorry to ask obvious questions, but you just never know.
Stills at: www.flickr.com/photos/trevor-dennis/
Trevor Dennis is offline   Reply With Quote
Old March 5th, 2013, 05:03 AM   #10
Same thing is happening to me. Here's the post I just added, along with sample frames:
http://www.dvinfo.net/forum/canon-eo...ml#post1782531
Mine are only happening for a frame at a time but are happening to almost every clip regardless of duration and card use.
I'd love to know if you or anyone has gotten to the bottom of this...
John Hewat
Mammoth Media Productions
John Hewat is offline   Reply With Quote
Old March 5th, 2013, 04:29 PM   #11
That really sucks. I would be PO'd. Pretty sure it is the camera, maybe try re-installing the firmware.
Scott Hutchcroft is offline   Reply With Quote
Old March 5th, 2013, 04:32 PM   #12
I'm extremely PO'd. I've got too much work coming up to be without the camera but can't really risk doing the work with this camera.
I've contacted my local repair centre and am awaiting their response about what they think. But if everyone here is right then it sounds like I'm gonna have to return it...
Another video producer I know said it looks like "data corruption of some sort. Dropped packet data. I've seen it before on downloaded movies from the net." If that's the case, could it be the card??
John Hewat
Old March 5th, 2013, 11:00 PM   #13
Response from the Melbourne service centre (spelling mistakes included):
"The faulty is a corruption: cane be caused by a card or camera.
Theses sensor or the main board can produce this fault or a faulty card.
Try a new card first and see how that goes.
If a new card does not work the camera will have to go to Canon Sydney"
So if it's the card, fine. If not, bad news. Especially since I bought it in Hong Kong...
John Hewat
Old March 6th, 2013, 04:42 AM   #14
Ok, so I'm confused.
As I started ploughing through all my footage from all cards to see if I could find other footage affected, I could not find one example.
Which initially made me think it was just the card.
Then I got to the footage that had been affected when I had (repeatedly) viewed it last night.
Tonight though, no problems!!!
All clips played perfectly!
I just don't understand it! Does that suggest some problem with my MacBookPro??
John Hewat
