#16 |
Re: Canon EF 300mm L, f4 & f2,8
Great thank for the quick response.
#17 |
Someone mentioned poor AF with the Canon 2X. I am afraid I don't own any of the 5D options, but I wonder if the latest 5D3 would be better for AF with a 2X. I am basing this on my 1D bodies (1DsMK3 and 1DMK4) both of which have surprisingly good AF performanace with a Canon 1x and cheap after-market 2X converters mounted together with a 70-200mm f2.8 - and this was looking at the moon, so hardly a bright and contrasty scene.
I beleive the 5D3 has an excellent AF system, so I suspect would be as good as my 1D bodies in this respect.
Stills at: www.flickr.com/photos/trevor-dennis/ |
#18 |
I find AF pretty good with the Canon 2X converter. I even use it on the Sigma 120-300mm f/2.8 OS (latest image stabiliser version) and it works great for stills (although I use manual most of the time for video).
The Canon 300mm f/2.8 is a superb lens and slightly sharper than the f/4 IS L version, although I do like the lightweight and compactness of the smaller lens, plus close-focus semi- 'macro' of the f/4. The f/4 IS L is a bit slower than the 2.8 L version in auto-focus, and also much slower than the Sigma f/2.8. I actually much prefer the Nikon Nikkor f/2.8 ED-IFN compared to the Canon 300mm f/2.8 L version, but in reality all provide sharp photos...and video is so much lower resolution than stills, that you would never spot the difference. So it all boils down to handling and light-gathering power. |
#19 |
Yeah, the 5D2 AF is a 2nd class citizen compared to the 1D line and the 5D3. Adding the 2x Extender II slowed things down to a crawl on the 5D2. The Mk III extenders are faster, and the 5D3 is much faster, so even though the extender will still slow things down, the overall speed is likely still very good.
I'd imagine that it depends on what you shoot. If it's smooth and at a distance, no problem. If it's unpredictable and close, every millisecond counts. But yeah, on the 5D2 with the 2x II, AF became frustratingly slow at times.
Jon Fairhurst |
#20 | |
Yes I find that the lens is sharp. It is much sharper than the Canon 70-200 2.8 L (version 1) that I also use. It is also easy to hand hold in low light. Paired with my Canon 5DM3 it makes a great pair when shooting low light event coverage. |
#21 | |
I have a 1.4x EF Extender II. Has anyone seen a significant improvement with the III? |
#22 |
I had a chance to try the f/4 300 on the MKIII and thought it was great for stills. Did not try it on the C300 since my Movcam rig with rails comes this week.
As many have pointed out the MKIII is a huge step up in that ability to grab the quick focus over the MKII. Thanks Canon this is a huge help with the f/4 300 and I bet with extenders. As for the extenders I have not had a chance to test any of them. If I was to just buy one it would be the 1.4x III. This is a extra 120mm and if I need longer then that I need longer glass. Also it should work well on the 70-200 which will fill a nice gap between the 200 and the 300. Sounds like I have made my decision. I appreciate all the great input and advice from all of you. Thanks! |
#23 | |
Here is a very good review that often compares the III and II versions of the Canon EF 1.4x Extenders. It's on a well respected camera site (albeit one primarily aimed at photographers rather than us video folks): Canon EF 1.4x III Extender Review Hope this helps.
Andy K Wilkinson - https://www.shootingimage.co.uk Cambridge (UK) Corporate Video Production |
#24 |
Thanks Andy that was a good read. I will go for the 1.4xIII.
#25 | |
#26 |
Jeff I think for the $100 difference it is worth every penny.
#27 |
Just received the EF 70-200 2.8L IS II. Wow, I forgot how nice this lens is to use and fantastic stabilization.
Next week the 300 and 1.4x which should work very well on the 70-200. Nice to finally have a glass selection to start using the MKIII on some still jobs. |
#28 |
Just an update to this thread for the people who spent the time to help me.
I have purchased the 1.4x III extender and EF 300 mm f/4L. Both will show up in the next two days. The 5D MKIII has been a fantastic for stills with my current glass: EF 14 f/2.8L, EF 24-105 f/4L IS, EF 70-200 f/2.8L II. Next on the list is the EF 8-15, and 17mm tilt and shift. Sure more will be needed but that will get me through the next few jobs. Thank you all for the help. |
#29 |
Gear arrived today and first test with the EF 300 f/4 IS and Extender 1.4x III on my 5D MKIII shows great promise. The zoom is very fast and the lens seems to be nice and sharp.
I did notice you do not want the lens switch on 1.5M distances with the extender, seems to get confused. With the switch on 2.5 is works great. This makes perfect sense to me. Also extender on the lens prior to lens on the camera is important. Of course the lens with out the extender works fantastic and you save a stop. Surprised how small this lens is not much bigger then my 70-200 and feels lighter. I think the MKIII focus is a very big help as we discussed. |
