MK3 Audio Delay at DVinfo.net
Canon EOS Full Frame for HD
Old May 4th, 2012, 05:40 AM   #1
Telecam Films
MK3 Audio Delay
Hello,
I recorded audio straight to the MK3 on a 25-minute interview yesterday and the resulting clips have a 2-frame delay. I could see a slight delay in the MK3 LCD while filming but I thought this was just a result of the live monitoring and would go away on playback. No luck. I fed the interviewee lav mic into a brand new SoundDevices Mix-PreD (recommended for DSLR audio) mixer and use the DSLR out with their Lemo to mini cable to connect it to the camera. I verified that there is no delay out of the Mix-PerD, delay is introduced by the MK3.
Anyone seen a delay?
Thierry Humeau, DoP
Télécam Films
www.telecamfilms.com
Thierry Humeau is offline   Reply With Quote
Old May 13th, 2012, 10:25 PM   #2
Re: MK3 Audio Delay
Hi Theirry
long time no chat ! yup dslr's have some delay between picture and sound. I saw about 1 frame on t2i / 60D's and I'm not surprised at 2 frames on mkIII. basically canon is failing to compensate for the delay in video processing / compression compared to whatever they do with sound. best thing is to visually slate and use dual system sound... or get used to sliding sound 2 frames. that said, canon's dslr sound leaves so much to be desired its not worth anything except reference track or oh S@#$! backup
Steve oakley
Steve Oakley DP • Audio Mixer • Editor • Colorist
http://stevenoakley.com
Steve Oakley is offline   Reply With Quote
Old May 14th, 2012, 06:55 AM   #3
Re: MK3 Audio Delay
I'm pleased to say that has not been my experience with the MK3. I have actually been delighted with its audio capabilities over the 60D and the MK2. Of course, I have yet to record any long interviews... about ten minutes max, so far. I'll admit I still dual record to the camera and to the Sony PCM 10, just in case, but knock on wood I've not needed the backup. The audio I record from one or two Sony wireless mics straight into the camera, with the camera's audio gain set to just under half way, has been crystal clear and in sync.
Charles Newcomb is offline   Reply
