5d mark ii external monitor at DVinfo.net
Canon EOS Full Frame for HD
Old March 24th, 2012, 10:11 AM   #1
Im shooting video with the 5d. I'm coming out hdmi and going into an Aja box and out hdsdi (bnc). When we record I lose picture. Is there a way to have an external monitor and and picture up while recording video?
Norman Furman is offline   Reply With Quote
Old March 24th, 2012, 11:28 AM   #2
Re: 5d mark ii external monitor
The 5d mark ii switches to SD when recording starts. Your SDI adapter may not uprez SD to HDSDI and if it doesn't your video will stop when you press record.
Try a HDMI monitor and you should see it go black for a second or two when you press record. You should get your picture back once the monitor adjusts to the SD HDMI signal.
http://www.LandYachtMedia.com
Old March 24th, 2012, 03:10 PM   #3
The only other way is buy a hdmi splitter and a second hdmi monitor.
Donald McPherson is offline   Reply With Quote
Old March 26th, 2012, 10:58 AM   #4
Or upgrade to the mark III?
Greg Fiske is offline   Reply With Quote
Old March 26th, 2012, 11:58 AM   #5
Can you explain how an hdmi splitter would help
Old March 26th, 2012, 12:55 PM   #6
For your specific problem it won't help.
Old March 26th, 2012, 03:26 PM   #7
Thanks for the info.
