EF-S lens on 5D, here's what happened...
So, what happens when you try to attach an EF-S lens to a EF mount? This thing falls out...
CANON EOS 5D Mark II Focusing Screen Installation Instruction Scary! good news is all you have to do is just put it right back in and snap the tray closed, but that will freak you out man! Bill |
Re: EF-S lens on 5D, here's what happened...
Can't quite tell from the link - does removing the focusing screen allow you to use EF-S lenses?
EF-S doesn't have enough coverage for FF - the vignetting will be outrageous.
It was an accident. I would not attempt it especially at a wedding.
#5 |
Tokina 11-16 is one exception.
#6 | |
-- peer
www.NoPEER.com |
#7 |
Exception in what way? In that there's no collision with anything or that it covers the sensor?
Need to rent camera gear in Vancouver BC? Check me out at camerarentalsvancouver.com |
#8 |
They would work exactly the same as the current screen - they have no effect in any way on video mode, whether using an external monitor or the built-in LCD. They are designed to improve manual focus when looking through the viewfinder and are thus only useful for still shooting.
My latest short documentary: "Four Pauls: Bring the Hat Back!" |
#9 | |
I have this lens and on the 5D 16mm is wider than at 11mm on the 7D. |
#10 |
Well,
All I can tell you is when my assistant tried to attach the EF-S lens to the 5D that screen popped out. Someone pointed me to that link after asking what this thing was and if I could fix it myself. Be warned :) |
#11 |
