which Nikon lenses can actually work on Canon? at DVinfo.net
Canon EOS Full Frame for HD
Old May 30th, 2011, 07:20 AM   #1
I am thinking of buying a 5D mk2 (or 7D I still haven't decided)/
I am a Nikon user, so I'd like to keep using some at least of my lenses using the Nikon to Canon adaptor.
especially a 105 Macro f 2.8, a splendid lens with VR (
will it work and will it retain all its capabilities including metering, manual/auto focus and VR? I am seeing quite a few adapters around and I can see most (if not all) do not retain any of those capabilities apart from metering
thanks
Fed
Federico Perale is offline   Reply With Quote
Old May 31st, 2011, 11:28 AM   #2
Re: which Nikon lenses can actually work on Canon?
Almost all Nikon Nikkor lenses can be used with the Canon 5D Mark II, but aperture control and VR will be lost when using latest AF 'G' Nikkors. This is why it is far better to use the older AF and MF Nikkor lenses which all have an aperture F/stop ring on the lens barrel to provide full depth control in video mode.
Manual Nikon Nikkor lenses are superb optics and work well with th 5D in video mode. Just don't expect all the bells & whistles of full aperture readout, AF, VR/IS etc when using Nikon glass on your Canon body. If you want all that you'll need to stick to Canon glass. I use Canon, Nikon and Pentax lenses with my 5D for both stills & video.
www.WILDCARP.com
www.NIKON.me.uk
Tony Davies-Patrick is offline   Reply With Quote
Old May 31st, 2011, 11:58 AM   #3
When you use the Nikon on the Canon the biggest challange is the aperture , hence that being on the lens works the best.
Thats where the old Nikkor lenses work wonders with the canon cameras.
I am not a big user in this category but i use the Old Nikkor 800 f/5.6 on my Canon 5D M II and i am impressed with what ever i have made in terms of video with this. Even tried the 600D on this lens and it made good images and videos with both the cameras.
hence till the time you have aperture that you can control on the lens, you are very good to go
Vishal Jadhav is offline   Reply With Quote
Old May 31st, 2011, 03:35 PM   #4
Contributor
I use my pre-AI Nikkors on my 5D, including a 24mm, 35mm, 105mm and 55 micro. All work great. I don't see any challenge with the aperture--the in camera meter is accurate.
Old May 31st, 2011, 04:58 PM   #5
Tony: what adapter are you using to mount Pentax lenses on your 5D? I own a BUNCH of Pentax K-mount lenses that I'd love to fit on the 5DMk2, but a brief search online found a site that said K-mount lenses couldn't be adapted. What's your secret?
Martin
Canon XF300, Canon 5DMkII, Canon XL2, Rolls MX422 mixer, Zoom H4N, AT899 lavs, AT2020's, Azden SGM 1X shotgun, Manfrotto 501 head on 351 tripod
Martin Catt is offline   Reply With Quote
Old June 1st, 2011, 12:30 AM   #6
Martin. Who ever said that is wrong. I have four K mounts I shoot with the 5D. No secret. Just buy an adapter. Check out ebay. They typically run a bit more than the Nikon to EOS adapters.
On one occaision, I had to do a bit of surgery on a flange on the back of a lens. (Can't remember if it was Nikon or Pentax mount.) But it did not affect the lens usability on the Canon cameras. The surgery may effect use in the orignial intended camera, but then I don't shoot those and I bought the lenses specifically for use with the Canons.
Chris J. Barcellos
Old June 1st, 2011, 05:04 AM   #7
Chris: the information came from the Fotodiox site, saying the rear element will hit the mirror. See the big red text on the page below:
Fotodiox
What brand adapter(s) are you using? I tend to stay with Fotodiox, even if they cost a little more, because their construction seems to be better -- tighter tolerances, no slop, plus you get infinity focus.
Martin
Old June 1st, 2011, 01:39 PM   #8
Martin, I mainly use Pentax 67 Medium Format lenses on my 5D using a special Pentax-EOS adapter.
Here is a link to more info on DVinfo forum:
http://www.dvinfo.net/forum/canon-eo...tive-view.html
www.WILDCARP.com
www.NIKON.me.uk
