Time Lapse - Page 2 at DVinfo.net
Canon EOS Full Frame for HD
Old May 30th, 2011, 10:08 AM   #16
Re: Time Lapse
I use an Aputure AP-TR3C
Aputure Limited - Digital LCD Timer Remote
As I recall, I bought mine through ebay for about $35. To get it to do brackets, you program the duration of the timer's shutter to be long enough to cover three clicks.
Jon Fairhurst
Old May 30th, 2011, 12:07 PM   #17
Re: Time Lapse
Originally Posted by Sterling Youngman View Post
Warren,
There were no clouds. So I can't imagine that was the problem.
-Sterling
Aha! You're right. Seeing that halo around the sun convinced me the sky was full of thin clouds because if I shot the same thing here, there would be no halo.
Old May 30th, 2011, 12:20 PM   #18
Re: Time Lapse
I believe that effect is due to a combination of diffusion and the brightness oversaturating the sensor. The more you expose, the wider the saturation area.
Jon Fairhurst
Old May 30th, 2011, 01:58 PM   #19
Re: Time Lapse
Jon,
When you bracket, the file names are sequential, so if you shoot a new still ever 8 seconds, that's 450 stills (per hour) per exposure level, or 1350 stills in total. How do you get them organized so that all the -2 exposures are grouped together and so forth?
Does my question make sense?
-Sterling
When you get to the end of your rope, you either hang or hang on.
Sterling Youngman is offline   Reply With Quote
Old May 30th, 2011, 03:21 PM   #20
Re: Time Lapse
I wrote a Ruby program that does that for me. It's on a different computer, but I can post a link later...
One of the biggest problems with bracketing is that it's a memory hog. For long runs, shooting JPGs might be necessary.
Jon Fairhurst
Old May 31st, 2011, 02:42 AM   #21
Re: Time Lapse
Again, this flickers because you are using the wrong settings. If you used "M" it wouldn't flicker. In 'AV' you are asking the TTL metering to pick the right exposure time in a scene with changing light levels - hence the flicker. You certainly shouldn't start trying to bracket or use 'AV' until you have mastered 'M' mode - all you are doing is wearing out your shutter.
Writer-Director-DOP
www.liamhall.net
Old May 31st, 2011, 08:54 AM   #22
Re: Time Lapse
You make a good point, Liam.
First, get perfect timelapses in "M" mode on non-sunset scenes. In fact, start with single photos and really learn to nail the exposure with minimal clipping. (That said, the sun will always clip.)
Also, don't be afraid to use smaller apertures. But note that you will want a pristine sensor and lens to avoid spots and blemishes.
Bracketing is only needed in two cases: 1) sunrise/set, and 2) when you want an HDR effect.
And before shooting timelapse HDR, master single shot HDR.
Liam is right about wearing out the shutter. It's good to make some initial tests to get a feel for timelapse, but the goal is to get 100% "keepers".
Jon Fairhurst
Old May 31st, 2011, 06:00 PM   #23
Re: Time Lapse
Folks,
Here's the latest.
I shot it in Manual mode, f22 @ 1/6, ISO 160, with 5 seconds between shots. Also, I shot RAW photos instead of jpegs
It plays back perfectly smooth on my computer. Vimeo tends to stutter sometimes. Once again, I ran out of clouds. It's a Southern California thing!
I put the vignette in.
Cheers,
Sterling
Old May 31st, 2011, 06:09 PM   #24
Re: Time Lapse
Nice! (Though I see the Vimeo stuttering too, and my PC should easily be able to play it.)
Jon Fairhurst
Old May 31st, 2011, 07:41 PM   #25
Re: Time Lapse
Just for sh!ts and giggles, you can download it from Vimeo and see if it plays more smoothly.
-Sterling
Old May 31st, 2011, 10:00 PM   #26
Re: Time Lapse
I downloaded it and it was smooth as can be.
I see that it's 29.97 fps (or so I assume - Windows says 29 fps. Duh.) Try re-rendering it at 24 fps or 23.976 fps to see if Vimeo can play it back smoothly. That will make your timelapses 25% longer for the same number of clicks. :)
Jon Fairhurst
Old May 31st, 2011, 10:14 PM   #27
Re: Time Lapse
I found this computer controlled slider that is at a reasonable price. I'm tempted, but I'm not sure if this time lapse thing is just going to be a passing phase for me.
Stage Zero Dolly 6-Foot Complete Kit (Back-Order Deposit) [DP6FK-BODEP] - $447.50 : Dynamic Perception LLC, Open-Source TimeLapse Motion Control Systems
Check out some of their example videos.
I found this product because this guy used it on his latest piece. It's very impressive:
MINDRELIC
Location, location, location!!!!
Cheers,
Sterling
Old June 23rd, 2011, 09:43 AM   #28
Re: Time Lapse
Here is another option for time lapse.
This was done with a Plotwatcher game camera from Day 6 Outdoors - Maker of the Flat-Out Feeder and PlotWatcher HD Time-Lapse Video . This camera films 720p HD time lapse and only costs 149.00.
YouTube - ‪TNTpromo2011.mp4‬‏
Kenny Hollingsworth is offline   Reply
