What would recommend for a minimalist 5dm2 kit? - Page 3 at DVinfo.net
Canon EOS Full Frame for HD
Old June 8th, 2011, 08:31 PM   #31
Re: What would recommend for a minimalist 5dm2 kit?
Originally Posted by Les Wilson View Post
I'm still getting used to the 5Dm2. It's disappointing to not have a live exposure and focus aids while recording. Unless I'm doing something wrong, both the live histogram and the 5x/10x turn off when record is pressed.
Nope that is normal behavior for the Canon's when recording. You will have to get used to it.
Daniel Weber
Daniel Weber is offline   Reply With Quote
Old June 15th, 2011, 11:01 PM   #32
The z-finder is wonderful. It creates a very solid platform for stabilizing handheld shots. Kudos to Olof Eckberg at Westside AV for the tip to use .6 and .9 ND filters along with a polarizer to manage aperture.
Old June 16th, 2011, 03:51 AM   #33
Any critical accessory you'd recommend for a minimalist starter kit?
For a "minimalistic" kit I think I would go for Redrock's "Captain Stubling":
Redrock Micro - DSLR "Captain Stubling"
-- peer
www.NoPEER.com
Old June 16th, 2011, 06:15 AM   #34
Hello Nigel.
Just wondered if you received your GGS LCD viewfinder yet, and, if so, what you think of it? The flip-up looks useful, but I wonder how practical it is to leave the rest on the body for viewing.
Roibeard MacEasmainn is offline   Reply With Quote
Old June 16th, 2011, 08:33 PM   #35
Originally Posted by Spiros Zaharakis View Post
Try this GGS LCD Viewfinder Loupes 3X For 7D 5DII 550D 600D ab41 | eBay UK it has diopter adjustments and it's cheap
Hardly minimalist.
Old June 17th, 2011, 02:55 AM   #36
Originally Posted by Nigel Barker View Post
That GGS LCD Viewfinder looks worth considering at about one eighth the price of a Zacuto Z-Finder. I have just ordered one from a supplier in the UK for just £42.50 (€48/$70) including delivery New LCD viewfinder For Canon 7D 5D Mark II on eBay (end time 13-Jun-11 03:21:25 BST)
Hardly minimalist.
I think adding a loupe to the 5DII is about as minimal as it gets after an ND filter.
Old June 17th, 2011, 03:02 AM   #37
Originally Posted by Roibeard MacEasmainn View Post
Hello Nigel.
The loupe is great. I used it for the first time at a wedding yesterday & was really impressed. My co-shooter was using a 5D with a Zacuto Z-finder & we swapped cameras a few times. The Zacuto is obviously better built but in use we both agreed that there was minimal difference. The optics are just as clear & sharp & the view of the screen is right to the corners. At one tenth of the price of the Zacuto it's a bargain.
The flip-up is pretty useless as it's just as easy to unclip the body & you do get a better view with the body removed.
Old June 17th, 2011, 06:58 AM   #38
Thanks for that review, Nigel. Very informative.
Old June 17th, 2011, 05:20 PM   #39
Nigel, my mistake. I meant to quote Peer like this:
-- peer
Old June 17th, 2011, 05:31 PM   #40
Hardly minimalist.
Well, if you were about to shoot a 3 weeks documentary, don't you think the "Captain Stubling" setup is still quite "minimalistic"..?
-- peer
www.NoPEER.com
Old June 24th, 2011, 02:44 PM   #41
As a b-camera I don't think the captain stubling rig is minimal...no. Just my opinion tho.
Old April 6th, 2012, 01:32 PM   #42
Hey guys,
Would you suggest a monitor with peaking or Magic lantern for pulling focus on the Canon 5D (version 2 and 3).
I am using the 50mm 1.4, 10mm 2.8, 70-200mm 2.8 and 24mm 2.8
Silas Barker is offline   Reply With Quote
Old April 6th, 2012, 01:52 PM   #43
Pulling focus using the LCD is difficult. Anything you can do will help. I can't speak for ML but on a 5DM2 the LCD changes to low res when you start recording. I'm not certain but I think the same is true on the HDMI. I find it difficult to see focus accurately on a 50mm and have to use 10x to get initial focus. After that it's a guess. I can't imaging doing it on a 24mm or 10mm unless your subject is really close. YMMV
Old April 6th, 2012, 04:01 PM   #44
Great stuff here. The lenses you have are great and should function very well. My setup, Canon 24-105mm f/4 IS, Canon 50mm f/1.4 and a Canon 70-200mm f/4. Backpack, monopod, LED light, Zoom H1 Recorder/Mic, wireless, 10 camera batteries, 8 AAA for mic. I always plan to have enough power for 8-10 hours shoots.
1. Use a viewfinder for critical focus and for use in bright areas. The LCD is workable alone but a viewfinder will enhance what your seeing. Plus it becomes a 3rd point of contact making your handheld shots steady.
2. Focus puller is very optional in my opinion. I can do just as smooth pulls reaching around the lens. Unless your wrist or fingers have bad arthritis its optional.
3. Vari-ND I would recommend this is bright situation to get depth of field controlled and where you want it to be. Often times I here people ramping up the shutter instead. This can lead to ISO/shutter banding.
4. Best and lightest support, a monopod. It you have to keep it simple and compact. My monopod has a simple manfrotto head which I can turn to 45 degrees and then it becomes a simple should rig.
www.m3films.com
Jeff Zimmerman is offline   Reply
