Crisis with Audio for a scheduled shoot at DVinfo.net
Canon EOS Full Frame for HD
Old December 11th, 2010, 08:34 PM   #1
Hi everyone,
I have a scheduled film shoot for a short film to be filmed in an apartment in a couple of days and the sound guy has back off at the last moment.
We will be using a Rode NTG-2 shotgun mic with boom and a ZOOM H4N to record the sound
Will some one be able to provide with the settings for the ZOOM H4N in order to record FULL HD AUDIO filmed by a 5D Mark II?
Ansab Khan is offline   Reply With Quote
Old December 11th, 2010, 08:48 PM   #2
Most any setting would work. Your DAW should be able to take in whatever you record with the H4n.
I'd recommend 48 kHz. Recording 24-bits doesn't hurt, though I know for a fact that the preamps won't give you more than 16-bits of signal. If you have limited storage, record in 16-bits. Certainly record uncompressed WAV rather than MP3.
Make sure the guy who controls the levels is wearing headphones. Record hot, but not so hot that it risks clipping.
Jon Fairhurst
Old December 11th, 2010, 09:49 PM   #3
i will be using only one external input of the boom mic into the H4N. should i record on single track (stereo mode) or dual track (using multiple track recording MTR mode) on the zoom h4h?
thanks
Old December 12th, 2010, 10:27 AM   #4
By the way Zoom H4n has the new firmware out V1.70
Download Software
Inna Lantsman is offline   Reply With Quote
Old December 12th, 2010, 03:31 PM   #5
You can record on the zoom and run a stereo mini to stereo mini from the zoom headphone to the canon 5D to record there too. Set your levels manually so you are not too hot. You'll have a solid audio track for syncing later on and if something goes wrong on either recording you have some insurance.
Denis OKeefe is offline   Reply With Quote
Old December 13th, 2010, 03:25 PM   #6
Contributor
To pass through the Zoom to the camera you need a cable with a pad. DVCreators.net sells one for $45. You need to load some -12db tone to your Zoom, play it back and calibrate the camera meters so they read what the Zoom is reading. But be careful because if you adjust your headphone gain up or down, you also change the Zoom's output to the camera. And if you use a Y-cable for monitoring, that will cut the output down as well, so you need to do the calibration with the Y cable in place.
Old December 14th, 2010, 09:26 AM   #7
There's a better and less expensive cable that was just released. It is a splitter designed for the Zoom H4N which has 25db pad and a headphone jack. Calibrate with the cable and with the headphones plugged in.
Sescom LN2MIC-ZMH4-MON 3.5mm Line to Mic with 25dB Attenuator for Zoom H4N with Headphone Monitoring Jack:
http://www.sescom.com/product.asp?item=LN2MIC-ZMH4-MON
Dennis O'Clair is offline   Reply With Quote
Old December 14th, 2010, 10:55 AM   #8
Right you are Bill -
My partner the soundman heard my request to feed the Zoom headphone out to my 5D, laughed up his sleeve, shook his head at my naivety and fed me a padded signal direct from his mixer.
Which by the way worked great.
Old December 14th, 2010, 11:43 AM   #9
I just checked with B&H and although this item is not listed on their site, it is indeed available by special order.
Old December 15th, 2010, 01:25 PM   #10
Contributor
Good find! Better and cheaper that what I got, and I had to buy the additional Y cable at Radio Shack. This is more compact and eliminates that extra connection. And cheaper. Nice.
Bill Pryor is offline   Reply
