5D and the Merlin mounting question. at DVinfo.net
Canon EOS Full Frame for HD
Old September 18th, 2010, 11:13 PM   #1
I've spent a couple hours trying to figure a way to mount the 5D to the Merlin Dovetail Plate and still have not figured out a solution. The problem being is the 5D has not location hole to stabilize the camera to the plate and it keeps coming loose. I know there are some using the merlin and would like to know if anyone has figured out a fix for this. I have tried gaffers tape with no luck. I would appreciate any help in this.
Bob
Bob Adams is offline   Reply With Quote
Old September 19th, 2010, 10:19 AM   #2
Contributor
I use the Merlin (with arm and vest) and have no problems mounting the camera. Is it possible you've replaced the original 1/4"-20 screw with one that's too long and you can't get it tightened down all the way?
Old September 20th, 2010, 10:44 PM   #3
No, I have the correct screw. I tighten it down really tight but it starts to move. There is no location hole to stop it from spinning. Any suggestions?
Old September 21st, 2010, 01:43 AM   #4
a bit of gaff tape on the plate helps cameras from slipping.
Brian David Melnyk is offline   Reply With Quote
Old September 21st, 2010, 01:44 AM   #5
hmmm. is that grammatically correct? need more coffee!
