Unable to import 5D video file to computer, HELP!
I have had no problem importing small under 1 minute test clips into the computer, but today, I ran a 8 minute clip at a wedding, and it does not import into the computer. It gives an error on the screen of the camera when i try to copy the file: Err 70 Shooting is not possible Turn the power switch to off or re-install the battery. PLEASE HELP!!!! |
It looks like you are copying the files off the card while it is still in the camera. Most people take the card out of the camera & use a Compact Flash reader. I use a Lexar FW800 model that is much faster than using USB. I suggest that you try a CF reader to rule out any problem with the camera. If the file itself is corrupt then you may still have a problem of course.
For anyone having this problem:
Just figured out the solution:
For small video clips under 600 mbs you can easily copy the video file, for video files larger or longer then that here is the solution: Install the ZoomBrowser software and copy files using that. It will take awhile but it does work. You can copy the footage directly from the camera with the card in it. |
#4 | |
-- peer
www.NoPEER.com |
#5 |
Why not? Camera have that CF reader BUILT IN. I have yet to see any proof that this operation damages camera somehow. According to the manual it is perfectly acceptable solution. On the other hand, every time you take out and insert the card the possibility of breaking contact pins and damaging the camera arises greatly.
#6 | ||
-- peer
www.NoPEER.com |
#7 |
Yes, I agree that there are situations where using a reader would be the only way to do it. So you have to specify that it depends on the situation. Simply stating "But why would you do that?" implies that this method is somehow incorrect.
#8 |
Unloading files using a FW800 CF reader is several times faster than hooking up the camera with a USB cable. There are now also eSATA CF readers which theoretically should be faster still.
#9 |
Sponsor: Westside AV
And on MBP's use the Express34 slot. It is 5-6 times as fast as USB on a Mac. And it is convenient no wires just an adapter the size of an Express34 slot.
Olof Ekbergh • olof@WestsideAV.com Westside A V Studios • http://www.WestsideAVstore.com/ |
#10 | ||
-- peer
www.NoPEER.com |
#11 |
What does Silas do when the card is full?
An external reader is what? 9.99 on NewEgg? I have them stuffed in every gear case I have... Silas...one day you may find it a waste to tie up the camera as a media unloader...it's a camera. Unloading/backing up cards may have to happen while you're shooting on the next card... Also keep in mind that the USB port on your camera probably isn't the fastest. A little card reader may speed you up by a considerable amount. I'm sure there is some sort of "pin breakage" risk... But since the industry as a whole removes media and transfers with some sort of card reader whether you're using SDHC, Compact Flash, P2 or SxS, i suspect it's slight.
TimK Kolb Productions |
#12 |
Hey everyone....
Thanks for the comments. I use the camera for video shooting and do not need a card reader as I can simply connect the camera to the computer and use Zoom Browser to copy all video clips and still images. If you needed to use the camera while backing up a card reader would make sense. For me its easier to just have extra cards or back it up when I get home from a shoot. As far as I know there is no risk using the camera. Its faster to copy with a card reader. |
