Vertical lines in blacks with Nikon AIS lens in low light at DVinfo.net
Canon EOS Full Frame for HD
Old June 3rd, 2010, 04:37 PM   #1
When in low light situations im getting these horrid vertical lines in the blacks with my Nikon lenses(50mm 1.4, 28mm 2) Anyone else suffuring from this or know the cause? Ill post a screen shot later..
Gerald Baillgergeau is offline   Reply With Quote
Old June 3rd, 2010, 06:35 PM   #2
I don't see any on mine. Most of the shots had to be at ISO5000,f1.4 so its super low light. If it helps, here is a clip.
Shot with:
-5DMK2
-Nikon 50mm f/1.4 manual
-ISO 5000
-30-fps
-1/30 shutter
-Neutral picture.
Audio:
-Zoom H4n
-Limit was set to Concert because it was LOUD in there. Loud!
-Volume at 55, Rec. level at ~2-5. Loud!
-Manual audio on 5dmk2, level at 1 point.
-H4n was wireless sending via ew100 g2 to my receiver g2 shoe mounted on the mk.
-Mono audio in -> mk2, stereo left fill in in Premiere.
No grading, no noise filter(post). So testing out how it looks online.
dcrin3.com
we don't know alot of genres, at least as of now.
Kalulu Ngilo is offline   Reply With Quote
Old June 4th, 2010, 02:45 AM   #3
Gerald, it sounds like you have too much gain (iso) turned up and are seeing the inherent flaws in the sensor. Since you didn't post which iso setting you are using, perhaps you are using auto iso and it is cranking up the gain too much.
Kalulu, your shot doesn't look at all like iso5000. There is very little noise and there is far too much light to need iso5000 with f1.4 at 1/30th shutter. The rope light and DJ lights should be totally blown out at iso5000 and the video screen would look almost totally white.
Old June 4th, 2010, 03:08 AM   #4
Doesn't sound like a lens issue for sure, almost certainly the sensor.
On the Phantom HD you sometimes get vertical banding and it's usually solved by black balancing - not a feature on DSLRs is it? It's a standard thing on pro video cameras, maybe it's required on DSLRs too, or is it mainly just for CCDs I wonder (though the Phantom is CMOS)?
Steve
Old June 4th, 2010, 05:53 AM   #5
believe me, it is ISO5k. It was the only thing that would work at those situations. Those dj lights are the only thing lighting that place otherwise it would be almost pitch black.
dcrin3.com
Old June 4th, 2010, 08:59 AM   #6
Do you have Highlight Tone Priority switched on?
If so, then turn it off.
Mike Hannon is offline   Reply With Quote
Old June 4th, 2010, 11:12 PM   #7
lol! I have never touched those settings. All of them are currently seating at 0 - disabled.
its just that simple. ISO5k, 1.4 on the 50mm @ 1/30. Believe it or not.
dcrin3.com
