Serreted edge 24 fps at DVinfo.net
Canon EOS Full Frame for HD
Old April 22nd, 2010, 05:17 PM   #1
Yikes, I figured the 24 fps what all were clamoring for would be better than the 30 but if anyone moves there's a serreted edge around the moving edge. I use Ciniform to convert the MOVs to AVIs then use NewBlue Color fixer etc in post. Is there a way to loose these edge serrations????
Should I always just shoot 30 fps from now on if moving folks?
TIA
Harry
Nashville TN using Canon 5D MK3, Canon 550D, RODE SVM mic, 70-200 f2.8L II IS, 24-105 f4L IS, 50 and 85 f/1.8, Vegas Pro 11, Zoom H4n, Blackbird, Lilliput Monitor, Lightroom
Harry Simpson is offline   Reply With Quote
Old April 22nd, 2010, 06:40 PM   #2
Haven't seen this at all in 4 hours of footage I've shot at 24, including a good deal of movement. I'd guess something's getting messed up in the conversion process, serrated edge sounds like interlacing.
My latest short documentary: "Four Pauls: Bring the Hat Back!"
Evan Donn is offline   Reply With Quote
Old April 22nd, 2010, 09:26 PM   #3
Do you use Cineform? Should I check the "Deinterlace" or the "Convert to 24p(NTSC only)" - right now I just have "Maintain source frame format" checked
Old April 22nd, 2010, 09:39 PM   #4
Sounds like somewhere in your process you have interlaced ticked. What program are you editing with, and how do you have it set up and ultimately to what for render?
Chris J. Barcellos
Old April 23rd, 2010, 03:48 PM   #5
Thanks Chris
Using Sony Vegas Studio 9 PE for rendering to Mp4 and using the NewBlue VE Color Fixer Plus to correct white balance etc.
I convert the MOVs to AVIs via Cineform HDLink application
In this the settings are
Automatically convert to Cineform Intermediate (*.avi) (checked)
Split file on scene changes (checked)
CineForm Encoder Options
Quality: High
Output source frame format (checked)
Old April 23rd, 2010, 03:50 PM   #6
Deinterlace and Convert toi 24p (NTSC only) is not checked (these are actually7 option buttons so whenever I check Maintain source frame format it unchecks these two anyway.
Old April 23rd, 2010, 11:18 PM   #7
Harry, what version of Cineform are you using ?
My version of NeoHD does not have the exact choices you reference. See image below for my Cineform selection for Canon 24p from 5D Mark II.
However, I wonder if you inadvertantly have the Mp4 output set at interlaced ? It should also be rendered progressive. I ve also attached screen grabs of how I set up the MP4 render.
Serreted edge 24 fps-neohdforcanon5d24p.jpg   Serreted edge 24 fps-frontsettingsmp4.jpg
Chris J. Barcellos
Old April 24th, 2010, 06:52 PM   #8
Thanks Chris!!
Reading this on an iPhone while traveling but will definitely compare and report back. Really appreciate this
Harry
Old April 26th, 2010, 12:05 PM   #9
Chris
I set up a new custom tmplate with your settins and the sucker rendered for about 4 hours to complete producing a mp4
I then tried to play it in VLC player and it would not play at all ...... More later
I think for now I better shoot 30 gps til I work this out
Harry
