Upper field First
I have been using a 5d M2 for some time and the clips were always reported as Progressive, since the 2.0.3 firmware update they are reported as Upper Field First. I have done some searching but have not found any info. Just curious to know if this is normal or not. I edit with Edius and when I put the clips in the bin the properities show upper field after the update and progressive before the update.
James |
Hey James, Check out this thread. It may help.
http://www.dvinfo.net/forum/canon-eo...mclip-fcp.html |
Thanks Jim
I was hoping maybe someone had the same situation I am seeing. Clips I shot the day before the update show progressive and clips I shot after the update show upper field first. I have not changed anything but something has changed. James |
I don't know anything about Edius, but I cut with FCP and I noticed some projects had some bad interlacing artifacts, but they completely went away when I switched field dominance to "none" (in FCP).
#5 |
Interlace handling in FCP is very bad. If you switch it to none, it will deinterlace everything that is set to upper or lower.
#6 |
Thanks guys
I guess I posted this in the wrong place, maybe it should of been in the firmware thread. I was just curious if anyone else had the same issue. It changed with the 2.0.3 update and continues with the 2.0.4 update. I can convert to Canopus HQ progressive and all is well, the properities just show the clips as Upper Field First since the 2.0.3 firmware update. James |
#7 |
I believe there is a note in the quick start instructions that says to select the newly converted files and change "upper field" to "none" after importing.
http://www.CredencePictures.com |
#8 |
Here it is from the .pdf Quick Start download:
