Cineform Neoscene bug? at DVinfo.net
Canon EOS Full Frame for HD
Old February 21st, 2010, 07:53 PM   #1
I've been using Neoscene to convert MOV files to AVI files to process in Sony Vegas 9 Studio. Been working great with v1.3.6 but after updating to v1.5.0 today it no longer will convert files without an error and no file is ever converted. Anyone else run into this?
Nashville TN using Canon 5D MK3, Canon 550D, RODE SVM mic, 70-200 f2.8L II IS, 24-105 f4L IS, 50 and 85 f/1.8, Vegas Pro 11, Zoom H4n, Blackbird, Lilliput Monitor, Lightroom
Harry Simpson is offline   Reply With Quote
Old February 22nd, 2010, 02:55 AM   #2
I had the same problem over the weekend.
It turned out you need to have the
"Cineform active metadata status viewer" running. It's the application that runs at startup and is located at the bottom right hand side of the screen in the quick icons.
Once that is running, you should be ok...... I think
Hope this helps
Gavin
Gavin Owens is offline   Reply With Quote
Old February 22nd, 2010, 06:28 PM   #3
solved
They sent another build that is working like a champ. They just built it this afternoon. 1.5.1.138
It seems to be working well now.
