Importing 5D files to Premiere Pro 4.2.1 at DVinfo.net
Canon EOS Full Frame for HD
Old December 26th, 2009, 10:43 PM   #1
Hi,
I have converted 5D MOV files to AVI files using a trail version of ProspectHD 4.13 but as soon as I import the AVI files to Premiere it crashes Premier, it gives me the following message;
"Premiere Pro has encountered an error"
"[..\..\Src\Timecode.ccp-995]"
My project is in Pal Mode
and I used the default setting in ProspectHD with Frame Rate Change of 29.97 to 25.0
Any idea what I am doing wrong please?
Cheers
Mitchell
Mitchell Yazdani is offline   Reply With Quote
Old December 27th, 2009, 09:56 AM   #2
When you created your project, did you use one of the Cineform Project (sequence) presets? I downloaded the trial last night and did not have any issues. Also, you might want to post this in the CineForm Software Showcase Forum at DVinfo.net.
Brant Gajda is offline   Reply With Quote
Old December 27th, 2009, 04:57 PM   #3
Hi
Thank you for the reply, I did try that as well and still the same, as soon as I imported the file gave me the error and PP4 crashed.
Old December 27th, 2009, 08:25 PM   #4
i thought PP can edit .MOV file. If so you don't need to use anything beside mpegstreamclip which is free. and convert the H264 to it. well i don't use PP so good luck
Thanh Nguyen is offline   Reply With Quote
Old December 28th, 2009, 09:03 PM   #5
I agree with this. Also Cineform support is available during the trial period; you can post a trouble ticket and they should point you in the right direction.
Charles W. Hull is offline   Reply
