30fps, to 29.97. - Page 2 at DVinfo.net
Canon EOS Full Frame for HD
Old August 13th, 2009, 05:17 AM   #16
Originally Posted by Nigel Barker View Post
As Olof already posted there is no need to buy any additional software. The OP is using FCP & will already have Cinema Tools as part of the whole Final Cut Studio. The Conform function is used to change frame rate. This works instantly as it just changes the frame rate in the file header there is no processing, conversion or rendering involved.
Hi Nigel. So presumably that will put the video out of sync with any external audio recorded at the same shoot?
Richard
Richard Hunter is offline   Reply With Quote
Old August 13th, 2009, 10:46 AM   #17
Good question Richard. I'd like to know this as well. I'm assuming if you're working in a 30fps timeline... slowdown the footage by .1 percent, then when it's converted to 29.97, it'l sync. That's just a theory. I'm sure someone will come along and have a solid answer.
"Warriors... Come out to play..."
www.importexporthd.com
Douglas Joseph is offline   Reply With Quote
Old August 13th, 2009, 12:46 PM   #18
Richard
Before you conform you should already have dropped that audio onto the timeline & synched it using the fabulous Pluraleyes plugin.
Old August 13th, 2009, 02:54 PM   #19
FCP automatically conforms between 30p and 29.97 if you drop one or the other into the opposite timeline with no rendering. No need to do anything external. If you need to deliver 29.97 just use that for your sequence settings when you edit.
If you are syncing external audio though you must start your project with a custom easy setup using a true 30p timebase as described on the pluraleyes blog here: 25 Hour Day: DSLR Dual-System Audio: The 99.9% Solution
If you start with that easy setup you can use either 30 or 29.97 in your sequences as needed and both video and separate audio will sync and conform properly without any need to do any retiming of audio or video.
My latest short documentary: "Four Pauls: Bring the Hat Back!"
Evan Donn is offline   Reply
