Wizard Status
Hyperfocal distance and depth of field display
I've just posted a demo video of some of the new features in the upcoming 0.1.6 Magic Lantern release: hyperfocal distance, depth of field readout and focus stacking: Magic Lantern - DOF and Focus stacking demo
I'll film another demo to show off the HDR capabilities with programmable bracketing. It's not really cinema related, but believe it or not, I get more requests for 5-11 exposure bracketing than 24p. If the early beta testers don't come up with any show-stopping bugs (list them here), Monday should be the release date. |
Thanks Tramm - looks interesting.
But can someone explain what 'Stacked Focus' is useful for? Will 0.1.6 include the option to set a 'Focus Pull' between A and B at variable speeds? |
Thanks, Tramm! So many great features for 0.1.6! Having DOF and Hyperfocal values on screen will make life much easier. And that automated focus pull will certainly get used. I understand there are some good changes to the GUI as well.
That HDR feature's going to be a hit. I've certainly wished it was available in the past. I'm going to have to watch for a project to experiment with the recorded camera information you mentioned. I'll be interested to see if it can be imported into virtual camera timelines for some applications. Many thanks to the you and your team! |
#4 | ||
Wizard Status
This is a feature that is begging for a remote follow focus controller of some sort. Trying to do it through the GUI is just painful. |
#5 |
Tramm...so is it the general consensus that 29.97 is not viable on the 5D?
And what is the status of HD output on HDMI during recording? |
#6 | ||
Wizard Status
It is something that I hack on occasionally to see if I can find the register in the DIGIC that the system writes into to set the frame rate. It might be useful to poke in the T1i/500D firmware to find what it writes to set the 20p frame rate and how the 1.0.9 firmware . Anyone have a sacrificial 500D? Quote:
#7 |
Thanks so much for the update. You are keeping up a very impressive campaign
on the Magic Lantern development. I love setting up shots with my DP1, but dislike recording with it. I had to crank the overscan settings to get everything on screen in 1080p mode, which causes the 480p mode to have awful bright green borders.[/QUOTE] I know what you mean. My daily Glidecam exercise sessions are done with the preview on th DP1 which looks stellar. Im dreading a real record for just the reasons you mentioned. |
#8 | |||
1. 'Select Start Focus' 2. 'Select End Focus' 3. 'Select Focus Pull Duration in ms' Are you saying that the Canon lenses are too unpredictable to allow these focus points to be consistently set? I'm also not sure if your plans include some kind of selectable 'ease in' and 'ease out' to the focus movement. Quote:
Last edited by Robert Esmonde; August 2nd, 2009 at 03:49 AM. Reason: Problems with the 'Quote' system selection of text |
#9 | |
Even if the start and end points aren't absolutely correct, as long as they are somewhat close, one could adjust the staging and/or camera position to compensate for the errors. Aside from spending $$$ on a wireless follow focus, there is no workaround for focus control on a gimbal rig today.
Jon Fairhurst |
