Rode mic
want to try my rode mic with an xlr to 3,5 mini adaptor, anyone using this set up and does it work
Hugh Mobley www.petplanetvideos.com http://exposureroom.com/members/hmobley.aspx/ |
I don't see any reason why it wouldn't. I have a Rode Videomic, but I also have an AT875 which I connect via a Juicedlink.
Equip: Panny GH1, Canon HG20, Juicedlink, AT897, Sennh. EW/GW100, Zoom H2, Vegas 8.1 |
At a minimum, you'd want a transformer in the adapter, rather than a straight cable.
Next, you'll want to run Magic Lantern firmware, otherwise, the camera's ALC will constantly adjust your levels, boosting noise in the quiet bits. Unfortunately, the Videomic Doesn't have a ton of gain. The result will be noisy. The sound will be much better if you can add gain with an active preamp, such as the juicedLink CX231 (with phantom power) or CX211 (no phantom). To get an idea what clean gain will get you, check out these videos. I recommend downloading the wave files and listening over good monitors or headphones, rather than hearing the compressed audio on computer speakers in a noisy environment. The Beachtek is passive. That will give you an idea of what to expect with a passive transformer adapter. 1. Canon 5D Mark II Audio Exposed - Boom Mic (juicedLink, Zoom H4n, Microtrack II, BeachTek) on Vimeo
Jon Fairhurst |
its a ntg 2 rode, and I guess I can use my zoom with the rode and bypass the camera, haven't tried magic lantern yet, does it still have any bugs
#5 | |
I hooked up my NTG-2 to my 5DMKII today and was pleased overall with the sound. The sound is as least as good NTG-2 to 5DMKII as it is NTG-2 to my XH A1. The cable I used to connect the NTG-2 and 5DII is described as: XLR to 1/8" mini cable/transformer; here's the link to the one I got. Nothing special but it works. http://www.bhphotovideo.com/bnh/cont...o.x=17&Go.y=13 Which I got from BHphotovideo for around $20. Good luck. Rog Lee Last edited by Roger Lee; July 25th, 2009 at 06:31 AM. |
