Magic Lantern 0.1.5 release - Page 2 at DVinfo.net
Canon EOS Full Frame for HD
Old July 8th, 2009, 03:59 PM   #16
This project sounds exciting and thanks for your efforts.
One question:
Is there any hope/possibility of ever getting a clean full resolution signal sent live out of the HDMI port?
Old July 8th, 2009, 04:53 PM   #17
I am guessing you are talking about live capture, with a card. So far, what I have seen coming of the camera doesn't seem like a full resolution HD through the HDMI port during capture, whether or not it is in proper aspect ratio. Of course, so far I have only viewed on a 19inch Dynex from Best Buy, and haven't tried it direct to my better HD monitors.... I will give it a look tonight.
Chris J. Barcellos
Old July 8th, 2009, 05:28 PM   #18
Right now the feed is not full resolution but just asking if the M.L. can address this or is Canon the only hope.
Old July 8th, 2009, 05:44 PM   #19
In general, Tramm can affect the control of the hardware and the overlays, but he can't change the processing of the video path. At least not yet.
It's possible that there is a bit that could be twiddled to stop the HDMI output from resizing to 480i, but that could be risky. My guess is that Canon downgrades the output to give the processing power to the h.264 encoder. Maybe they restricted the resolution to fight a heat problem.
In any case, Canon chose to downgrade the HDMI output during recording for a reason, and it's not just to keep people from recording uncompressed video from the sensor. We can do that by simply not pressing the record button. (To remove the focus box, enable face detection, or push it out of the way and record roughly 2:1 aspect video.)
Jon Fairhurst
Old July 8th, 2009, 06:13 PM   #20
This is same conclusion I came to, after just running some more testing just minutes ago.
I Magic Lantern, there is a fairly clean HD signal before hitting record, and if you clear the screen you may get what you are looking for. Though I am not sure what aspect ratio you will actually get.
If it can be done, Tramm will do it though.
Chris J. Barcellos
Old July 8th, 2009, 10:24 PM   #21
My thoughts were towards not recording with the 5D but recording to a Nano Flash.
If it is possible to output a full resolution feed at all then this would be a great alternative.
This method would not need to have the 5D recording, so is there a chance this could work without another firmware update?
Sorry, I own the camera for stills but have not had the time to try any video with it.
Old July 8th, 2009, 10:44 PM   #22
Tim:
Like everyone else, you will be doing firsts here, if you can get it going. All you will need:
1. I assume you have the Nano.
2. A mini HDMI to standard HDMI cable
3. A copy of latest Magic Lantern firmware, 0.1.5, and learn how to load it.
You could set camera up the way you want it in the config file. I would leave of zebras and crop. Crop doesn't quite mark right on HDMI out at this point anyway.
You have to set up Live View to videon and Still, and be sure to select the movie view over exposure simulation. Other wise you will have auto on.
If you need help with getting it going, PM me, and I will try to help.
Chris J. Barcellos
Old July 8th, 2009, 10:52 PM   #23
Hello Chris,
Thanks for your interest.
I have a Nano on order. Don't know when I will get it, but it should be in a few weeks.
So I can not test this yet but I wanted to see if it was worth pursuing.
Sounds like it is.
Right now, is the HDMI video signal full resolution, uncompressed sent live out of the camera?
The M.L. update can turn the screen graphics off but the full video image does not get sent out? Is this correct?
I will be happy to forge new territory when the Nano arrives!
Old July 8th, 2009, 11:25 PM   #24
Tim,
The HDMI stuff is a bit off topic, but here goes:
* The HDMI output generally reflects the image on the LCD display.
* Playback from the card is 1080 widescreen
* When not recording or playing back, the output mirrors the LCD, which is 4x3, so you get a cropped pillar box display. That means that the output is not full width 1920. It scales down by throwing away lines and pixels, so the aliasing is really bad. It is uncompressed though, so you don't get block artifacts, but the aliasing kills it for me.
* The focus box blocks the image, but you can push it out of the way and get a clear 2:1 image or so. You can definitely get 2.35:1 unobstructed. I hear that if you turn face detection on, it removes the box.
Since this is a sticky for 0.1.5 firmware, any questions about current HDMI operation should be on another thread, rather than this one.
Jon Fairhurst
Old July 8th, 2009, 11:37 PM   #25
Tramm,
I've confirmed that the audio gain is incorrect on the first take. The gain is correct on the following takes. Also, the first second or so of all the takes gets a quick blast.
As mentioned earlier, when capturing audio, just do a quick dummy take after loading the firmware, then do your real takes. You can see when the audio settles down on the audio level monitor.
Jon Fairhurst
Old July 9th, 2009, 08:02 AM   #26
Wizard Status
I believe based on code, but have not been able to verify, that the output is only 960x540. This may be incorrect with the HDMI output and I plan to run some extensive tests this weekend to determine the resolution.
Tramm Hudson is offline   Reply With Quote
Old July 9th, 2009, 09:42 AM   #27
Thanks.
Tramm, I sent you an e-mail to take the conversation off of this thread.
Old July 14th, 2009, 03:42 PM   #28
Installed it...worked a treat. VERY impressed!
Philip Bloom Blog Archive Magic Lantern 5dmkII firmware. Brings loads of great features to the camera
Philip Bloom
Old July 14th, 2009, 05:45 PM   #29
magiclantern.cfg
What is the value in the .cfg file to have Zebra's enabled? 0= not enabled does 1=enabled? Would be nice to have a FAQ on the settings values for the .cfg file or better yet #more descriptors for the possible values in the cfg file.
# Zebra levels
# Zebra draw = 0 off 1= on
# Zebra.level = 61440 default more transparent = ?????
zebra.level = 61440
zebra.draw = 0
Default .cfg file below:
# Zebra levels
zebra.level = 61440
zebra.draw = 0
# Edge detection (too slow for real use)
edge.draw = 0
# Crop marks for 2.35:1
crop.draw = 1
# Audio data
# mgain is according to this table:
# 0 == +0 dB
# 1 == +20 dB
# 2 == +26 dB
# 3 == +32 dB
# 4 == +10 dB
# 5 == +17 dB
# 6 == +23 dB
# 7 == +29 dB
audio.mgain = 4
# dgain is in dB.
audio.dgain = 12 # dB
# mic-power is boolean. Turn it on if you are using an electret mic
audio.mic-power = 0
# Enable liveview automatically?
# Turn this off if your card has trouble booting or
# with HDMI output connected at boot time. You will need
# to hit the Live-View button in a few seconds after booting
enable-liveview = 1
# Disable the powersave so that the LiveView never shuts off?
# WARNING -- this can cause problems with your sensor!
# DO NOT LEAVE THE CAMERA ON CONTINUOUSLY.
disable-powersave = 1
Regards
Steve
Steve Cahill is offline   Reply With Quote
Old July 14th, 2009, 10:22 PM   #30
Correct. 1 is enabled and 0 disabled for all binary values.
Jon Fairhurst
Jon Fairhurst is offline   Reply
