Diy dslr slider
May be of value for DSLR Video enthusiasts. Basic inexpensive camera slider. My concoction, for better or worse.
DIY DSLR SLIDER on Vimeo Ron |
Now that's inexpensive ingenuity!
Unfortunately, my laptop skips frames. How smooth does it feel/look? Do you wish you had something with bearings, or is your solution as good as you would want? Thanks!
Jon Fairhurst |
a Great idea, but is having baby powder around a camera with interchangeable lenses really a good idea?
#4 | |
DIY Slider
Ron |
#5 |
Baby Powder
#6 |
Brilliant! I have a broken garage door opener. Maybe I can mod it into a slider. Too bad the motor is so bloody loud! Of course, not having to lift a 400 lb door means that I can use a tiny motor to do the job.
This morning, while in the shower, I realized another problem with the wood/powder approach. I live in the Pacific Northwest US. The rainy season is about eight months long. An outdoor wood/powder slider sounds like a gummy proposition up here! Is it true that in order to rain in Australia, it would have to fall up? ;)
Jon Fairhurst |
#7 | |
To Slide Or Not To Slide
There are a range of commercial slider options available. Some push or pull...So the same limitations regardless. Another has a lead screw and nut...Hand cranked. All cost buckets of gold. Ron |
#8 |
Isn't that the truth! And follow focus units are even worse, considering that the whole operation takes just four gears - two of them with straight-cut teeth.
Too bad sheep don't lay golden eggs. :)
Jon Fairhurst |
