Editing 5D & XHA1 footage together: bad plan? at DVinfo.net
Canon EOS Full Frame for HD
Old May 5th, 2009, 05:11 AM   #1
I have a forthcoming project I want to shoot on the 5D, but I might need to shoot a couple of scenes on an XHA1 simply because it has a longer lens.
The XHA1 scenes will be completely different situations from the rest of the footage and the whole package is reportage rather than narrative, so I'm not concerned about getting the different footage to "look" the same. But what other traps are there? What about the different frame rates? I'm sort of assuming that the best thing is to convert all the footage to Pro-res, but really I'm guessing.
Has anyone got any work flow suggestions?
Many thanks.
Jeremy Nicholl is offline   Reply With Quote
Old May 5th, 2009, 05:30 AM   #2
Subscribing to this thread
I have the same situation so will be watching this thread to see what people think.
Fred LeFevre is offline   Reply With Quote
Old May 5th, 2009, 02:51 PM   #3
It depends on your editing software, really. Different formats are no problem in Adobe CS4, although I'd recommend sticking to a common frame rate for footage that is going to be intercut (unless you are specifically planning to speed up or slow down the footage of one of the cameras).
Pete Bauer
Old May 5th, 2009, 03:01 PM   #4
Since you are in a PAL country, the easiest way to work is to slow down the 30p footage to 25p. This assumes that you won't use any audio from the 5DII and that you like the slight slow motion look. (I like it.) If you need real time conversion to 25p, that's more complicated. Adobe After Effects is a good base tool. You can use their built-in stuff, and 3rd party plug ins are also available.
For NTSC countries, it's simple enough to slow 30.0 to 29.97. For edits with sync'd video, you'd need to slow that audio by 0.1%, but only for the 5DII clips, not for the standard camera clips.
Jon Fairhurst
Old May 5th, 2009, 03:03 PM   #5
I have tried this.
I shot the A1 in 24fps and the 5d in 30fps (of course). I ended up transcoding both to ProRes which felt like a added burden (it would be nice if one of the formats was edit-friendly). The 5d made the A1 feel like standard def. I still haven't decided how I will work next time because there are so many trade-offs.
If you are shooting with the A1 for a long lens, wouldn't it be easier to just rent or buy a cheap zoom for the A1?
http://www.michaelfriedman.org/
Michael Friedman is offline   Reply With Quote
Old May 5th, 2009, 03:41 PM   #6
I have tried editing the XL-H1's footage with the 5D.
I converted both to ProRes, Technically it's fine
it's just that...
The 5D footage looked sooooooooo much nicer nicer than the HDV
It was hard to intercut.
But it sound like you will be using different cams in different situations and that could work nicely
good luck,
J
John Benton is offline   Reply With Quote
Old May 5th, 2009, 06:58 PM   #7
They are about as different as night and day, but I intercut them anyway.
Daniel Browning is offline   Reply With Quote
Old May 5th, 2009, 08:25 PM   #8
I don't understand this. I thought the term "long lens" referred to how long the lens was physically, meaning like 200mm up, or whatever.
But the lenses on the 5dmk2 are interchangeable, so couldn't you just put on a long lens?
Joshua Fulton is offline   Reply With Quote
Old May 5th, 2009, 08:45 PM   #9
To get the same angle of view and light gathering power as the XH-A1 lens would require a 650mm f/8.5. And the zoom capability would require a 32.5-650 f/4-8.5.
Old May 5th, 2009, 10:18 PM   #10
You cannot achieve that zoom range on the 5DII but you can approach it with a Sigma 50-500mm F4-6.3. Very long telephoto lenses can be had very cheaply although they are often more like cheap telescope with a Canon EF mount. Here's an 800mm for less than the equivalent of $250. Falcon 800mm f/8.0 ED Mirror Tele Lens for Canon New! on eBay, also, For Digital SLR, Camera Lenses, Photography (end time 31-May-09 11:02:33 BST) Given the price the quality must be questionable but you could always use a Canon 'L' telephoto with a 1.4x or 2x teleconverter if you really need that long shot.
Old May 6th, 2009, 03:04 AM   #11
My ideal solution would be a 500 or 600mm f4L perhaps plus converter on the 5d, but I don't own those and they're not available for rental, hence the XHA1 solution.
Since the whole thing will be run and gun - or more likely stumble and fumble - I'm not sure I even have the option of slowing the 5d frame rate in post [I'll be using FCP], since at least some of the audio will come in through the camera. Audio that doesn't will go to a Microtrack, but I assume that if I then slow the camera frame rate I'll have terrible problems syncing the audio.
Here's an odd idea. Since the audio on one of the XHA1 shots won't be critical, why not increase the frame rate to 30fps to match the 5d? The shot will be vehicles moving, so it shouldn't look unnatural if they're slightly quick. And the piece will only ever go to web, so 30fps shouldn't be a problem. I think.
Old May 6th, 2009, 03:21 PM   #12
I believe Cineform's Neo Scene adjusts the 5D mk II's footage to 29.97 fps and adjusts the audio to suit.
Julian
Julian Frost is offline   Reply With Quote
Old May 6th, 2009, 06:23 PM   #13
The Stillmotion crew still intercuts 5D MkII footage with Canon XH-A1 footage shot using our adapter. This is a better match as the DOF and overall look of both rigs work well together. In low light, the 5D is much cleaner and ends up a few stops more sensitive than the XH-A1...so I suspect it will become their standard for very low light shoots.
Cheers,
Dennis Wood
www.cinevate.com
Dennis Wood is offline   Reply With Quote
Old May 13th, 2009, 05:14 AM   #14
i did my first one last weekend. Combined EX1 + Canon A1 + 5DII. Footage turned out different like day n nite! The 5D2 (Neoscene) looked similar to the EX1 footage when one goes at 29.97p and the other at 50p. However the A1 really stood out at 25P.
I am also figuring out the best way for PAL land integration. I tink i will likely to shoot 25p for EX1 and hopefully they will turn out not too different.
Sean Seah is offline   Reply
