Event DV review and 30p to 24p conversion. at DVinfo.net
Canon EOS Full Frame for HD
Old April 12th, 2009, 11:05 PM   #1
EventDV.net: Hot Fusion: The Canon 5D Mark II and the Wedding Filmmaker
I found this article very helpful in working with the 5dmk2.
Short Summery:
-Hand held is shaky get a shoulder mount for the camera
-use compressor when converting to 24p (I bought the cineform and don't recommend it over compressor. Compressor has better and more options.)
-Good low light for weddings.
-They also give a couple of tricks for keeping the f stop fast.
Winston Ashley is offline   Reply With Quote
Old April 13th, 2009, 12:14 AM   #2
Cineform isn't really for 24p conversion. It automatically conforms the 30p video to 29.97 by slowing playback, but doesn't do true frame rate conversion. Instead, it's an intermediate codec. It's an alternative to ProRes on the Mac.
I use the PC, generally with Vegas. I've found that After Effects is a good tool for frame rate conversion. That said, I like to slow down the content 80% from 30p to 24p when there's no dialog. It's a perfect conversion, and it takes no processing. The slight slow motion effect often looks great. If you only perform true 30 -> 24 conversion on the scenes with dialog or that can't be slowed, you generally don't have to process quite as much as compared to converting the whole thing.
Jon Fairhurst
Old April 13th, 2009, 02:53 AM   #3
It was a good article. Thanks.
I am really interested in workflows for editing sync footage with the A1. They mentioned it briefly but I would love more detail. Like the interview they shot with the real estate guy. That had 5D and A1 footage. To use the 5d you would have to batch export all of the clips before editing. Or edit them in out of sync (30p vs 24p) and just convert the ones that make the final cut.
This is my number one problem with the 5d at this point. Mixing it with my A1/Letus setup.
http://www.michaelfriedman.org/
Michael Friedman is offline   Reply With Quote
Old April 13th, 2009, 04:46 AM   #4
In the article around 1:30 he mentions the rig they use... the shoulder mounted rail system... does anyone know what the brand of rig is that they are showing??
Old April 13th, 2009, 07:18 AM   #5
I believe that it is a rig built by Cinevate. If you go to their website and look at the bottom of the products page you can see the rig. It appears that the "cage" around the 5D can be used for a small laptop when being used with other cameras. It also appears that the cage is only part of a milti-rail system, shoulder and tripod mounted.
Kyle Ehrenreich DP Professional Video Productions
Kyle Ehrenreich is offline   Reply With Quote
Old April 13th, 2009, 03:47 PM   #6
As Kyle mentioned, its the Cinevate rig. www.cinevate.com I have their 35mm adapter, great stuff.
I believe they have :
1) Cage
2) Proteus Rails
3) Hand grips + Shoulder pad (sold together)
The cage can also used to mount mattebox and even as a handle to carry the thing around.
Randy Panado is offline   Reply With Quote
Old April 13th, 2009, 05:29 PM   #7
Thanx guys... I think your right...
Old April 16th, 2009, 09:59 AM   #8
Still Motion
hey guys
glad you enjoyed our little piece. it was a little silly, but talking about these things can get dry pretty easy.
i have 6-7 different presets in compressor for the 5d depending on the type of source footage and what i want to do with it. i am working on getting the audio sync perfect all within compressor.
the handheld rig is from cinevate. we kept bugging them to actually put together a package for the 5d. ours was home built from spare parts so there rig will be somewhat different and better. compared to the zacuto it is super affordable (theirs is like $3.5k). the cage is awesome - I would get that, rails and grips as a low cost start.
P.
Patrick Moreau is offline   Reply With Quote
Old April 17th, 2009, 01:22 PM   #9
Hi Jon,
I am really interested in doing what you describe as 80% slow motion. I am using PP CS4 and AE CS4, can this be done with the Windows version too? If so, do you mind providing some details.
I also came across this video, witch turned me on to the effect. I would really appreciate any tips you can provide. According to Marco, he just did the following:
"I conformed the 30p footage to 24p using Cinema Tools with the Batch Conform tool. Takes 2 seconds to do with no re-encoding needed (basically just changes the metadata)".
5D Mk II Low Light Testing @ Agave Nightclub on Vimeo
And this is my video that I think would look nice in slow motion:
http://vimeo.com/4113067
Rick
Rick Casillas is offline   Reply With Quote
Old April 17th, 2009, 03:05 PM   #10
OK. As far as I remember:
Open a Premiere project with a frame rate of 24 fps.
Import your clips.
Select all clips in the Project panel
Right click > Interpret footage
Change the frame rate in the dialogue box to 24
Place clips on timeline - voila!
Mike Hannon is offline   Reply With Quote
Old April 17th, 2009, 03:55 PM   #11
Thanks Mike.
I will give that a try.
Rick
Old April 17th, 2009, 05:39 PM   #12
That did the trick, thanks.
Rick
