5D mark II for interviews going to NTSC at DVinfo.net
Canon EOS Full Frame for HD
Old March 19th, 2009, 12:43 PM   #1
Wondered if anyone had experience doing double system sound and synching the sound later? I have a potential project that would have interviews that would then have to eventually wind up on NTSC at 29.97. Any suggestions appreciated.
Norman
Norman Bonney is offline   Reply With Quote
Old March 19th, 2009, 01:17 PM   #2
Double system sound is the way to go. Just match up the timing with the sound from the onboard mic. This is easiest with interviews (since things are said only once, unlike a film with many takes) and with concert videos (where you can narrow down the song and then the lyric.)
Jon Fairhurst
Old March 19th, 2009, 02:28 PM   #3
And a simple hand clap on camera/recorder once rolling will make syncing easy as cake.
Bill Binder is offline   Reply With Quote
Old March 19th, 2009, 02:36 PM   #4
yes.... I've used my korg mr-1000 with matched rode nt-1a mics or at987 shotguns for audio with my 5d2...... recording 1-bit then exporting 24 bit and for a 5 minute take the audio will only need to change speed to 100.1%
I use the iphone timeslate app for a slate/clap
Christopher Witz is offline   Reply With Quote
Old March 19th, 2009, 04:06 PM   #5
Images: 1
This sounds great, but I could not find it. Have a link for the app?
John Gyovai is offline   Reply With Quote
Old March 19th, 2009, 05:42 PM   #6
Home ?(iSlateClapperBoard)?
Bob Thompson is offline   Reply With Quote
Old March 19th, 2009, 05:42 PM   #7
here's the one I use.....,
Slate
Old March 19th, 2009, 06:32 PM   #8
Images: 1
Great! Thanks much for the links. It looks like Slate has a "beep" flash when it closes. This seems useful, but I guess islate makes the sound sound the clapper is down. Juts wondering which one would be better. Any thoughts?
Old March 19th, 2009, 06:34 PM   #9
It might be worth it to also clap at the end also, given that no one is quite sure what the true frame rate of the 5D2 is. That gives you two impulse sounds to work with.
Jay Bloomfield is offline   Reply With Quote
Old March 19th, 2009, 08:02 PM   #10
Images: 1
You see Jay, that's one of those things I would not think to do the first two months. Good idea!
Old March 19th, 2009, 10:07 PM   #11
Slow footage down after?
Do those who end up in NTSC land slow the footage down to 29.97? I'm not that post savvy so I'm not sure what the concerns of the editor would be going out to something for broadcast.
Old March 19th, 2009, 10:09 PM   #12
The difference is so small you can ignore it, except if you are worrying about running time.
Mark Hahn is offline   Reply With Quote
Old March 20th, 2009, 12:08 AM   #13
I'd slow it down. That way you'll never risk a skipped frame.
In fact, if there is no dialog, you can slow it down by 0.8 - and get 24p. That's how I've been approaching it on a music store video I recently shot. ;)
Jon Fairhurst
Jon Fairhurst is offline   Reply
