Does the focal length rule apply in video mode? - Page 2 at DVinfo.net
Canon EOS Full Frame for HD
Old January 30th, 2009, 07:10 PM   #16
Yes, a ND filter is the solution. Although, it seems there isn't any solution for the focal length = shutter speed rule. Unless, the manual mode or twisted lens.
Mathieu Kassovitz is offline   Reply With Quote
Old January 30th, 2009, 07:17 PM   #17
Back to the topic
Chris, how can you get ISO 800 with 1/50 shutter with EF lenses other than with the 50mm one?
Maybe it's all the same from 30th to 100th shutter but I'm loosing more light with 1.2 85mm than with 50mm 1.8 because the apparent focal length to shutter speed rule.
Rack focusing is also almost impossible with USM fulltime electronic manual focus that might be the case of 1.2 L only. Straight from the cam http://www.autonomicum.com/forums_up/MVI_0017_bela.MOV (hear the inconstancy of my hand turning the electronic focusing barrel).
T
Toenis Liivamaegi is offline   Reply With Quote
Old January 30th, 2009, 07:24 PM   #18
The risk is that the tape falls off and gums up your shutter or sensor. I taped a cheap lens - and now I have no idea where the tape ended up.
I like the mylar ring idea much better. Maybe some holes can be cut for power. The key is to find a way to keep it from rotating.
Tape or mylar. You are correct. The mylar ring idea is better.
Old January 30th, 2009, 07:35 PM   #19
T
I've been seeing 1/30th most of the time with my 85 1.2 II....
Christopher Witz is offline   Reply With Quote
Old January 31st, 2009, 01:09 PM   #20
There is who has mentioned the focal length = auto shutter speed rule is misleading because it applies only for taking pictures during video recording. Is that so?
Manual Control. The Truth !
Shutter, Aperture, ISO-Display: Are they all wrong?
