Canon EOS EF mount pin readout! at DVinfo.net
Canon EOS Full Frame for HD
Old January 21st, 2009, 08:54 AM   #1
Ever wondered if there are any ways to use the marvelous 85mm at f1.2? I mean not in the lowest of lights but outdoors etc.
As many of you already know twisting method will disable any focusing with many ring type USM lenses and using ND's seemed to be the only option and still valid for getting normal shutter speeds.
I've been wondering that with just placing a small transparent piece of tape on the last 3 pins of the lens will discard/disable aperture data but the focusing power will remain.
The tape should be placed on the right hand side of the lens when looking at it, if I'm not mistaken. At least so you can lock the aperture but use focusing motor on those fly-by-wire "L" series like the magical 85mm f1.2.
So, the Canon EOS EF mount pin readout at the camera body is:
(Left to right, looking at the front of the body)
1. VBAT
2. P-GND 3. P-GND (pins 2 & 3 are common on the lens)
4. VDD
5. DCL
6. DLC
7. LCLK
8. D_GND
Pin Functions explained:
VBAT - Motor power
P_GND - Motor power ground
VDD - Logic circuitry power
D_GND - Logic circuitry ground
DCL - Data from body to lens
DLC - Data from lens to body
LCLK - Clock
Data protocol: Motorola SPI; 8 bit serial; Such as the protocol used with the 68HC05 chip. (hint hint for FF makers) I assume the few RED EF mount makers use the same chip.
Experiment on a cheap lens first, as this so far is only in theory!
Cheers,
T
Toenis Liivamaegi is offline   Reply With Quote
Old January 21st, 2009, 11:15 AM   #2
Thank you for the info. Maybe you can post a small photo of the tape as you've applied it? We will make this into a real cinema camera! :)
me@facebook: http://facebook.com/stevemallerphotography
Steve Maller is offline   Reply With Quote
Old January 21st, 2009, 11:27 AM   #3
I tried some tape on a cheap lens. And then it disappeared. I hope it's not in the camera.
I won't be applying any more tape, unless there's a way to ensure that it stays put.
Jon Fairhurst
Old January 21st, 2009, 02:14 PM   #4
lol...that first statement was just worded in the most hilarious way.
I would seriously be tearing apart my camera looking for that piece of tape. Things like that bug me. I lost a lens cap once in my bag and after 5 minutes of tearing the thing apart I found it.
Randy Panado is offline   Reply With Quote
Old January 21st, 2009, 07:29 PM   #5
Jon: Sux .. most likely, when you mount the lens there is a friction point and the tape probably dislodged. Most likely, it's in your camera body.
Old January 22nd, 2009, 12:44 AM   #6
I hope not. So far, there's no trace.
Jon Fairhurst
Old January 22nd, 2009, 05:43 AM   #7
I tried it every way and it didn't work with 85mm 1.2L, no focusing power.
Old January 22nd, 2009, 06:07 AM   #8
So are you saying that this "taping method" would at least allow you to use the lens at 1.2, but with manual focus? That would be OK... similar to the twist method, but at least the lens is locked in place.
that is if the tape stays on... sorry John....
Oh, and a note to the wise... if you come across the old 85mm1.2 L going cheap, it had power assisted manual focus, so taping/twisting, means no focus on that baby...
Darren Jew | sunny Queensland, Australia
... learning about moving pictures after 25+ years of still ones ...
Darren Jew is offline   Reply With Quote
Old January 22nd, 2009, 06:50 AM   #9
New version, MKII 85 1.2 has also power assisted manual focus if I'm not mistaken, I have that EF 85mm 1.2 MKI and my colleague has MKII and this too can not manually focus on DOF adaptor for example...
T
Old January 22nd, 2009, 07:06 AM   #10
T
thanks for the clarification. I was just going off the specs here
Canon Australia - EF 85mm f/1.2L II USM
that mention full time mechanical focusing. Shame.. looks like it will be the nikkor...
Old January 26th, 2009, 12:39 AM   #11
1. VBAT
4. VDD
5. DCL
6. DLC
7. LCLK
8. D_GND
VBAT - Motor power
LCLK - Clock
Cheers,
T
I've been thinking of getting some thin mylar, cutting it to just cover all the pins, and then punching holes where the GND pins are (2, 3, & 8). I'm hoping those three holes would keep it in place. Any thoughts?
Mark Hahn is offline   Reply With Quote
Old January 29th, 2009, 01:27 AM   #12
I now have a better idea for how to use the mylar that involves no holes and will be much easier to insert and remove. If interested see http://www.dvinfo.net/conf/1002979-post13.html
