slowing down (not converting) 30 fps to 24 fps at DVinfo.net
Canon EOS Full Frame for HD
Old December 20th, 2008, 04:48 AM   #1
Hi all, thanks for the forum.
Am new here and new to video courtesy of the 5dmkii, so am a sponge at the moment.
I think I understand the process of converting 30 fps to 24 fps so that a clip stays the same length as the original.
Audio issues aside, if I shoot at 30 fps, is there a way that I can export all the captured frames at 24 fps, effectively "slowing down" (and making longer) the resulting clip?
Darren Jew | sunny Queensland, Australia
... learning about moving pictures after 25+ years of still ones ...
Darren Jew is offline   Reply With Quote
Old December 20th, 2008, 08:47 AM   #2
Originally Posted by Steven Schuldt View Post
.......(edit)
I have been playing with the "slowdown" workflow and I'm pretty excited about this, actually. Workflow (on Mac OS X) goes like this:
- Copy raw captures from 5D Mark II CF card to desktop.
- Open in QuickTime Pro.
- Export as Apple Pro Res 422 (HQ), 1920x1080, stereo 44.1khz (this is a very fast export)
- Open in Cinema Tools and conform to 24p (instantaneous)
- Open in Final Cut, create new project, drag clip into browser allowing sequence settings to conform to clip.
- Add clip to Timeline and double-click to open in Viewer
- Add Effects>Audio Filters->Apple->AUPitch
- In Viewer edit the AUPitch settings Pitch->300 (cents, I believe, meaning 25 percent pitch correction)
.......(edit)
Steven, I'm interested to know if you have found this to be a workable process, and if you have any examples of how it looks....
thanks
Old January 17th, 2009, 03:59 PM   #3
23.976/30 = 0.7992
Simply slow your video down to 79.92% and it will be 1fps in a 23.976 sequence.
If you are actually working with 24fps and not 23.976fps, then slow the video
down by 80%. This will slow down your video so you don't lose any frames and
your video will be longer.
I tried it in Premier Pro CS4 and it worked perfectly.
Clint Decker is offline   Reply With Quote
Old January 17th, 2009, 04:17 PM   #4
thanks Clint, will give it a try.
Old January 17th, 2009, 06:54 PM   #5
Images: 2
Just open a clip in cinematools and reconform to 23.98- no codec conversion necessary. Then edit inside of a 23.98 timeline in FCP.
HR|cinematographer
HunterHRichards.com
Hunter Richards is offline   Reply
