What does "Shutter" mean? at DVinfo.net
Canon EOS Full Frame for HD
Old December 17th, 2008, 12:04 AM   #1
What does an electronic shutter really mean? How can a camera that apparently has a 1/2000th electronic shutter have a slow read/reset? How can there be "jello" with a 1/2000th shutter? Is it technically surprising that the Canon seems to have such a fast electronic shutter?
Don Miller is offline   Reply With Quote
Old December 18th, 2008, 10:05 PM   #2
An electronic shutter is essentially the effect of turning the sensor on and off again (I'm not an electrical engineer, so hopefully someone with more knowledge than I will come along and post up a more detailed description).
The Canon 1D has a maximum electronic shutter speed of 1/16000, and the 1D Mark III's fastest speed is 1/8000. One-two-thousandth of a second does not impress me at all.
Daniel Bates is offline   Reply With Quote
Old December 18th, 2008, 11:54 PM   #3
My understanding is that the electronic shutter refers to the amount of time each photosite is allowed to gather light.
On a CCD all sites start gathering light and then are read out at once. On a CMOS each line is read sequentially - and the light gathering period and read period are tied together. So each line may be gathering light for 1/60, 1/125, 1/2000, 1/n of a second, but the time it takes to read all of the lines from top to bottom will always be the same and is determined by the speed at which it can process the data. The amount of skew is determined by how long it takes to read all the lines, not by how long each line gathers light.
My latest short documentary: "Four Pauls: Bring the Hat Back!"
Evan Donn is offline   Reply With Quote
Old December 19th, 2008, 07:40 AM   #4
So doubling the ability to read the sensor may cut the skew in half.
The term read/reset refers to the whole sensor? It seems to me that the number of channels and processor is a major factor in reducing skew. That's good because that's controllable.
I'm not bothered by the 5D skew as much as some people here.
Old December 19th, 2008, 11:46 AM   #5
Me either.
But, if I were going to film a ping-pong match, I'd grab a CCD camera.
Jon Fairhurst
Old December 19th, 2008, 01:31 PM   #6
Yes, and I'm not an engineer so I'm just going by what I've gathered over the past couple of years since I got my first CMOS-based camera (sony HC1). It had noticeable skew, and I read somewhere that they reduced that when they shipped the EX1 by adding an analog-digital converter to each line of the sensor which allowed them to process the data faster. However that didn't fully eliminate the skew, and I think what it comes down to is a balance of power & heat.
You probably can build a CMOS with no skew, but it might only be suitable as a studio camera because the processor would draw too much power to be battery powered, and would then generate too much heat to be passively cooled - especially in a compact camera body. The EX1 has a slot through the body with a fan to keep it cool as it is and it still isn't able to eliminate skew. I would imagine it takes a lot more processing power than the 5DmkII since it has 3 chips, which is probably why the 5D can do what it does in such a small body with no active cooling and smaller batteries. However they've clearly had to push it close to some heat limit and thus had to add the emergency shutdown capability to prevent people from frying the sensor.
Old December 19th, 2008, 01:33 PM   #7
Me either.
Me either, but now I have this sudden desire to go out and shoot a ping pong match with my 5D just to see the skew...
Old December 19th, 2008, 02:36 PM   #8
Check out Beijing Hoop Dreams by Dan Chung from about 1:40 for an idea of what ping pong might look like: 5DmkII - Beijing Hoop Dreams on Vimeo
I find that tracking motion in one direction isn't much of a problem. The skew can feel a bit organic. But once the camera reverses direction, it's jello-land.
I think it's also worse when telephoto. A short lens ads its own distortions, so it masks skew, but a long lens can really make problems apparent.
Just last night, we were trying to get two photos to fit a given frame size. We cropped as much as we could artistically, but neither quite fit. We found that we could simply squeeze our angled, wide-lens building shot, and it looked completely natural. We tried that on the straight telephoto shot, and it didn't work at all. Maybe if we stretched the edges, but left the middle clean, it would work...
Jon Fairhurst
Old December 20th, 2008, 05:10 AM   #9
I guess a slower shutter speed decrease the perception of this effect, it's probably hardly noticeable with 1/60 shutter speed (the same skew happen, but as motion is more blurred with longuer exposure, human eye will hardly see the difference on low frequency informations). So this effect should not be much of a problem for film-like (slow shutter) applications.
Robin Lobel is offline   Reply With Quote
Old December 21st, 2008, 10:52 PM   #10
It has many meanings.
  • The movable louvers on a pipe organ.
  • To close down. "The factory has shuttered temporarily."
  • To tremble with a sudden convulsive movement, as from horror, fear, or cold. "The airplane shuttered in the turbulence."
  • To make silent. "She's too loud, shut'er up."
  • A person that shuts.
  • To stop or cease operation. "Time to go home, shutt'er down."
In the context of the 5D2, I believe the correct meaning is "movable louvers on a pipe organ". The slowness of the pipe organ explains why the camera has skew/wobble, and also the AGC and noisy pre-amp in the onboard sound.
Daniel Browning is offline   Reply
