1/60 shutter speed the sweet spot for 5d? at DVinfo.net
Canon EOS Full Frame for HD
Old December 13th, 2008, 07:58 AM   #1
I have been mainly using the HVX200 for shooting and always set it to 180.0d instead of choosing shutter speeds (unless I need a certain look). Is 1/60 a similar look to 180.0d?
Jay Birch is offline   Reply With Quote
Old December 13th, 2008, 09:08 AM   #2
The 180 degree setting is an exposure of half the frame duration. On the 5D MkII (30fps) that would be 1/60th. If it shot 24fps (we wish!), it would be a shutter of 1/48th at that frame rate.
For a slight over crank, use 1/60th, slow the playback to 24fps, and you'll maintain that 180 degree look.
For an under crank, set the shutter to 1/30th (360 degrees), then drop every other frame. Now you have 15fps at 180 degrees. Speed up to 48 fps and the 180 degree look is maintained - with fast motion, of course.
Not exactly RED frame rates and ramps, but we have to make due!
Jon Fairhurst
Old December 13th, 2008, 09:23 AM   #3
thanks mate, i thought that would be the case.
Old December 13th, 2008, 04:11 PM   #4
This is all academic though unless you have a camera that lets you choose the shutter speed yourself...
My latest short documentary: "Four Pauls: Bring the Hat Back!"
Evan Donn is offline   Reply With Quote
Old December 13th, 2008, 09:16 PM   #5
Sad but true! (I'm hoping I can learn to trick the thing...)
Jon Fairhurst
Old December 14th, 2008, 01:25 AM   #6
Is it possible to set it to 1/48th?
Mathieu Kassovitz is offline   Reply With Quote
Old December 14th, 2008, 02:09 AM   #7
"Is it possible to set it to 1/48th?"
Not at the minute, it jumps from 1/40 to 1/50.
James Miller is offline   Reply With Quote
Old December 14th, 2008, 09:50 AM   #8
Merci. As a consequence, Canon is limited. A better 25 frames conversion for 180 degree motion than converted it to 24 frames.
