#76 | |
#77 |
People, this is not that difficult to understand. No one should be expecting perfect sync for long periods, it really is that simple.
If you are: (1) using a separate device to record audio and (2) not fully timecode jammed/synced, then drift will -- in all likelihood -- occur to some extent or another. That's true for even the most pro recorders in existence and may occur regardless of 30 or 29.97 fps or 44.1 vs. 48 kHz. Even two SD744s will potentially drift from one another over extended times if they aren't jammed, and that's two of the exact same high end units. So, if you don't have drift problems over extended periods, you should consider yourself lucky, and if you do have drift issues, you should consider that to be pretty normal. |
#78 |
To me, the dual-system single system comes down to one thing: Redundancy. One little blip of static can ruin a shot unless you have a second audio source.
(In one particularly telling moment, my acting-DoP, who was really my PA, who was filling in for my REAL DoP who was arrested for terrorism - long story - actually forgot to turn on the microphone for a few minutes while recording. I'm damn glad the backup audio was running then!) I record dual system when I can, but I always make sure to use the really good stuff on the camera if I have to choose between the two. I'd rather have a good audio track on the camera than have to sync in post. I've recently become a convert to the XLR workflow - get a Juicedlink or Beachtek - I prefer the former for the preamp - and you should be fine.
Equip: Panny GH1, Canon HG20, Juicedlink, AT897, Sennh. EW/GW100, Zoom H2, Vegas 8.1 |
#79 | |
-- peer
www.NoPEER.com |
#80 |
does anyone know of a way to monitor mic levels BEFORE they get into the camera? I was thinking some type of small adapter that the mic could plug into before going to the mic input on the MK2?
