Problem with Canon 5D Mk. II video? - Page 2 at DVinfo.net
Canon EOS Full Frame for HD
Old September 28th, 2008, 12:22 PM   #16
Originally Posted by Alexander Ivanoff View Post
BTW: ProfotoRGB works well only 16bit mode. In 8bit mode may cause problems like solarization etc.
I see that when I switch the videos to ProFoto RGB in Photoshop, but not in AE, not sure what the difference is there.
interesting thing though - I just thought I'd compare this to a DVCProHD clip from a project I'm working on shot on an HPX500. I get exactly the same results as the 5D. I'm thinking this is simply a result of 8-bit conversion from NTSC-safe YCrCB to RGB - and the d90 is probably not converting to 16-235 so it doesn't display the same errors. None of them show any gaps in LAB.
My latest short documentary: "Four Pauls: Bring the Hat Back!"
Evan Donn is offline   Reply With Quote
Old September 28th, 2008, 12:40 PM   #17
What container of DVCProHD clip? quicktime(mov)?
Alexander Ivanoff is offline   Reply With Quote
Old September 28th, 2008, 12:53 PM   #18
Yes, quicktime from P2 using log & transfer in FCP.
Old September 28th, 2008, 02:31 PM   #19
I found same problems with any mov file imported in CS3 (h.264, sorenson 3,
except mjpeg)
Problem with Canon 5D Mk. II video?-79.jpg   Problem with Canon 5D Mk. II video?-78.jpg
Old September 28th, 2008, 06:06 PM   #20
is 76 a .mov with mjpeg? or an avi like the nikon footage? I know there are some issues with quicktime clipping superwhite values on export from FCP, I'm wondering if this is related.
Old September 29th, 2008, 10:05 AM   #21
76 is mov with mjpeg inside
h**p://finalpass.net/videos/MJPEG_test/MJPEG-720p-2MBps.mov
Old September 29th, 2008, 09:20 PM   #22
As we see the problem at the moment:
- 5D Mark II writes signal in QuickTime H.264 MOV-file in its full quality.
- Apple QuickTime Player can adequately display these MOV-files.
- But most NLE,s (Edius, Vegas, Premiere, After Affects, ...) perceive these MOV-files in a distorted form (see attached image):
--- Shadows and Highlights is lost (red zone);
--- The subtle gradations is lost (gaps in the histogram).
It is pretty much a known problem 'quicktime gamma shift' (search Google). For example: DV - Columns - Brighter Whites; Richer Colors, Part 1
Either we are waiting for improvements in the NLE. Or need a utility that correctly converts MOV-files in a format suitable for NLE.
The decision has not yet been found.
Ivan Pin is offline   Reply
