Unusual problem, won't auto focus. at DVinfo.net
Canon EOS Crop Sensor for HD
Old June 13th, 2012, 03:17 PM   #1
Hey all, can't seem to figure out what setting I've changed, and hope maybe someone can help me out. I have a 60D, with the latest version of Magic Lantern on it. Use to, when I half pressed the shutter button, it would auto focus. It will still do this if I go to auto mode, but any other mode, and it doesn't auto focus any more. All I get is a flashing star next to the battery icon, when I'm looking through the eye piece. Can't figure out what I've changed. Anyone have an idea?
Thanks in advanced,
Jeff
You motorboating SOB!
Jeff Troiano is offline   Reply With Quote
Old June 14th, 2012, 12:04 AM   #2
Re: Unusual problem, won't auto focus.
Yeah, you probably inadvertently changed to "back button focus."
It's in the custom functions: C.Fn IV -1
Watch this video:
Jordan Hooper is offline   Reply With Quote
Old June 16th, 2012, 03:30 AM   #3
Jordan is right, I have the same problem
Matija Petrovic is offline   Reply With Quote
Old June 17th, 2012, 08:57 PM   #4
Thanks guys, you were correct. Im not sure how I got in there and changed the settings to begin with. But all is good now.
Old March 4th, 2013, 11:22 AM   #5
Hey guys! I'm new in here... I'm from Costa Rica.
I sent my camera to the repair shop in order to try to fix this issue (Half-way shutter button will AF and inmediatly shoot), thinking that was the shutter button the one causing the issue. No internal issues on my camera but still getting the issue .
I thought it was the update I made from firmware 1.1.0 to 1.1.1... so I downgraded it to 1.1.0 but same issue/ Upgraded to 1.1.1 and same issue... and used the latest Magic lantern and same issue.
Cleared all possible functions and same issue. Replaced battery, same issue. Replaced card... same issue... used like 5 different lenses... same issue...
On my case... I can see the focus point but inmediately it will take the picture.... I'm also able to autofocus using the AF-ON button but I don't really know what's happening in here...
I've already done this. All custom settings to default, C.FN IV: Operation/Others: AF and metering buttons is set to 0 so:
Meter & AF Start
Meter & AF Start
AE Lock
Yesterday I even tried 1.0.9 firmware but same issue
Any other way to solve this?
Can you please advise what is wrong with the camera?
Thanks!!
JC
Juan Carlos Solorzano Lara is offline   Reply With Quote
Old March 4th, 2013, 11:49 AM   #6
This may seem simple and silly. But what lens are you using? And is the auto/manual switch set to auto focus? I briefly had a similar issue. Was doing something and flipped to manual focus. Once I was done, I forgot to switch back to auto focus. When I would press the button half way to focus and meter, it would only snap a picture.
Just a thought.
