Magic Lantern Mic Power with DR100 into t3i at DVinfo.net
Canon EOS Crop Sensor for HD
Old May 21st, 2012, 06:49 PM   #1
Hi.
I'm using latest ML and want to feed DR100 line output into the t3i mic input via Sescom 3.5 Line to Mic 35dB Attenuator cable, bypassing internal mic. Anybody know the proper ML Mic Power setting in this case? The user's guide states below, but I'm still unsure:
Mic Power: ON/OFF
This is required for internal mic and certain types of external mics, but it reduces
input impedance.
• ON: input impedance is 2 kW
• OFF: input impedance is 30 kW
This setting is always ON when input source is either internal mic or L:int R:ext.
Any input is appreciated. thanks.
Amos Kim is offline   Reply With Quote
Old May 23rd, 2012, 07:56 AM   #2
Re: Magic Lantern Mic Power with DR100 into t3i
Off is safer since you don't need Mic Power in this situation. But if it works with it On, you can leave it there if you ever need to power a mic through the jack.
Brett Sherman is offline   Reply With Quote
Old May 23rd, 2012, 01:33 PM   #3
Thanks for the input Brett. Off was what I was leaning towards but not knowing so much about audio, was confused by the impedence issue.
