Does APS-C have lower resolution? at DVinfo.net
Canon EOS Crop Sensor for HD
Old April 5th, 2012, 01:27 PM   #1
I just wondered, because of the crop factor, does the Canon have a lower resolution than the 5D? It makes sense to me that, by "zooming" in on the image of the mirror 1.6x, it'd have less definition.
Charles House is offline   Reply With Quote
Old April 5th, 2012, 01:54 PM   #2
re: Does APS-C have lower resolution?
Resolution is the same.
Laurence Kingston is offline   Reply With Quote
Old April 5th, 2012, 02:06 PM   #3
I think you're mixing a few things up there.
There is probably some relationship between resolution and sensor size. But in the sense I think you're talking about there isn't a direct relationship. If an APS-C size sensor has a lower resolution than the 5D it's because the sensor itself has fewer pixels. It's not necessarily related to size.
The crop factor is not a case of zooming in as such, but a way of accounting for the sensor's smaller field of view. Most of the way we comprehend the focal length of a lens is in relation to a 35mm image. When people think of, say, a 50mm lens they have an idea what sort of field of view you are going to get from that already. But that is only true on a 35mm camera. Canon APS-C is, I think, about 22mm. So using a 50mm lens on that will have a smaller field of view than it would on a 35mm. The ratio of 1.6 tells you roughly which focal length would achieve the same field of view on a 35mm camera (so a 50mm lens on an APS-C has roughly the same field of view as an 80mm focal length on a 35mm camera).
Hopefully that makes sense. Clever people will surely be along soon to point out where my terminology is messed up.
Murray Christian is offline   Reply
